Page 1 of 2
1985 spree
Posted: Tue Oct 14, 2008 11:16 pm
by hondaken
Is there anything that I can do to make it go faster without buying parts?
Posted: Wed Oct 15, 2008 1:51 am
Short answer, NO!
Posted: Wed Oct 15, 2008 10:22 am
by noiseguy
Have you read through Adv Tech Docs? Spree can be sped up with a file and some time, but you need to read up first.
Posted: Wed Oct 15, 2008 10:38 am
by needfasterthan31
take the airscrew completely out.it will do 40 miles per hour then youll seize the piston and scratch the cylinder up.
Posted: Wed Oct 15, 2008 4:38 pm
by Kenny_McCormic
There arent any "parts" for it.
Posted: Wed Oct 15, 2008 4:46 pm
Kenny_McCormic wrote:There arent any "parts" for it.
Didn't I say that in the second post in this thread?
Posted: Wed Oct 15, 2008 4:52 pm
by Kenny_McCormic
He said without buying parts.
OP: You can make a spree hit 40 with $100, a welder, and a dremel. But I doubt you can handle it.
Posted: Wed Oct 15, 2008 4:54 pm
by hondaken
OP: You can make a spree hit 40 with $100, a welder, and a dremel. But I doubt you can handle it.[/quote]
Hows that?
Posted: Wed Oct 15, 2008 6:21 pm
by Kenny_McCormic
Port it out
build an ex chamber pipe
get head milled
get pulley milled
Posted: Wed Oct 15, 2008 7:17 pm
by hondaken
Too much work, plus I don't want to give up low end power. I did file the intake tube some, I think I'll file some more, that didn't seem to help much. thanks for the info though.
Posted: Wed Oct 15, 2008 8:02 pm
by evilone
Just curious what you mean "intake tube". Are you talking about the intake port? :?:
Posted: Wed Oct 15, 2008 8:31 pm
by Kenny_McCormic
You wouldn't lose any bottom end from stock configuration. Intake tube is the pipe between the carb and engine.
Posted: Wed Oct 15, 2008 8:52 pm
by needfasterthan31
only drive down big hills and lean forward.
Posted: Thu Oct 16, 2008 1:58 pm
by hondaken
needfasterthan31 wrote:only drive down big hills and lean forward.
lol yea, I'v hit 45 thatway, that was a fun hill
Posted: Thu Oct 16, 2008 11:30 pm
by devenex
lose weight :lol:
