broken manafold bolt
zeolig
Post by zeolig »
I need some advice again. Short of welding the manafold is there a way of stopping a leak between the manafold and the muffler. When I picked up the Spree the back tire was flat and off. I noticed when I removed the muffler to reinstall the tire one of the manafold bolts were broken off. I tightened up the one bolt but there is a leak. It looked flush but it was still leaking Not to loud but loud enough. I do not want an exhaust leak to lean out the engine and cause any damage. Anyone aware of a quick fix such as a gasket or muffler cement as a glue between the pipe and the manafold? I tried putting a bollt through the broken hole with lock washers but it kept slipping out. Any ideas would be greatly appreciated. zeolig
dig hard dig fast
keithw
Post by keithw »
The manifold stud is screwed into the cylinder. The broken one will be a bugger to remove but once you get it out you just screw a new one in. I would not even try to repair it with the cylinder on the bike. This would be a good chance to check to see if you have a dished piston and replace it with a domed one, port the exhaust, and mill the head.
Another option would be to go to your local auto parts store and pick up some exhaust gasket material. Cut a gasket and install between the pipe and the port. Is the copper ring missing from yours? It goes between the pipe and the port. If missing it doesn't seal very well.
keithw
Honda Spree, 1985.
Another Honda Pal
zeolig
Post by zeolig »
I'm not sure if the sleeve is missing. I'm in work but I will check when I get home. I will try the automotive store suggestion because the bike runs great and I would like to go for the quick fix at least until winter sets in. Maybe during the winter months I can back the bolt out of the block. Would I use heat or mystery oil or something like that when I try to remove it?
Thanks zeolig
dig hard dig fast
Diesel Spree
Post by Diesel Spree »
if any of the bolt is sticking out take a torch and heat it up becareful not to melt it then take a vice grip and turn it out and u can get a new one from the dealer for .79 cents or u could drill it out and retap it and just put a bolt in there.
if it dont smoke its broke
Post by Kenny_McCormic »
warm it up with a torch just hot to the touch
spray it with PB blaster
walk away
repeat a couple of times
heat again and try turning out with vice grips.
zeolig
broken manafold
Post by zeolig »
Thanks all. The injury to the manafold was a little more extensive than I thought. Part of the manafold was broken exposing the threads where the bolt used to be. I got a thick manafold gasket, cleaned the manafolf and muffler flange real well,slid it over the sleeve, which was still there and used some muffler cement. I tightened up the one bolt, no leak. I'm scooting quietly. zeolig When I first drove it the headlight was working great. Last time I started it I noticed no head light high or low beam. Is there a fuse for the light and if so where is It? If not is a headlight hard to change. Thanks again. zeolig
dig hard dig fast
For a more permanent repair if it give you problems later: You could push a new stud into the remains of the thread, and have a muffler shop spot weld the stud in place. Otherwise you can replace the jug to repair.
Admin, Hondaspree.net
zeolig
Post by zeolig »
Thanks! Sounds like a winter project. zeolig
dig hard dig fast
