sym dd50 air box
perdog02
sym dd50 air box
Post by perdog02 »
quick question..if you deristrict it like a elite what size jet do you need? the sym has a rubber plug in it and if you remove it it runs like crap. it already has an 88 jet in it...how much bigger do you need to go? i seen only going to an 80 for the elites..
tru72
Post by tru72 »
on the SYM when i do derestricts at the shop i usually put a 100 jet in them. if not i have my jet drills at the shop , i can dril them out to whatever size you like!
aloha
D
maddog
Post by maddog »
What! #100 jet on a stock engine= remind me not to go to the shop you work at :evil:
tru72
Post by tru72 »
shakes head...
have you done a sym derestrict? you change the pipe, and remove all the factory restrictors. It still falls under warranty.
oh yeah by the way perdog. The stuff for your set up. I Just called the distributor and he said he had what i was looking for! come by the shop, if this weekend is nice lets go for a cruise!
aloha
D
perdog02
thanks d
Post by perdog02 »
hey d thanks for the info ill stop by one day.
my co-worker seen the post so ill have him stop by and see you for the jet.
perdog02
thanks
Post by perdog02 »
Thanks for the jet D. And in case you others were wondering the 100 jet in a derestricted sym DD50 works just fine.
tru72
Post by tru72 »
awesome, im glad that worked!
once he does a few more small things that stock Bike should get close to 50 pretty easy. He needs to change his variator, springs.. i jus did a order with taiwan so i can get him hooked up with some good prices!
aloha
D
maddog
Post by maddog »
Ha Ha, thats funny cause a 66cc bore kit uses a #100 jet & is a joke on a 12mm carb for the sym= nothing beats an old school honda :lol:
