Impact Wrench
Posted: Wed Oct 22, 2008 4:10 pm
by paulbrown137
I think I need to add one of these to my toolkit. Any benefit of air over electric? Any recommendations on brand or amount to spend. I dont need pro quality, but dont want cr@p. I've read getting the wheels off without one is a PITA.
Posted: Wed Oct 22, 2008 4:49 pm
by evilone
I've heard electric impacts are convenient but over $400.00, Sears craftman air impact should be all you need. I'm thinking around $140.00? but then you need compressor.
Posted: Wed Oct 22, 2008 5:00 pm
by Kenny_McCormic
You can get a cheapo electric one at harbor freight for under $100, probably under $50, they work fine.
Posted: Wed Oct 22, 2008 9:07 pm
by noiseguy
Air tools are smaller, but require a compressor. Electric tools are usually larger and heavier. I have one of each, I prefer the air tool.
Posted: Wed Oct 22, 2008 9:28 pm
by burnt_toast
Kenny_McCormic wrote:You can get a cheapo electric one at harbor freight for under $100, probably under $50, they work fine.
CHEAPER THAN THAT! Electric impact $20 at harbor freight when on sale!
It's one i highly recommend for scooter tuning, works great. and as far as quality I've had mine for over 3 YEARS! if it breaks I would have no regrets and easily buy another one, plus you can get 1yr warranty for like extra $5, cant beat it man.
air impact is not recommend because easily strips threads.
Harbor freight impact link:
http://www.harborfreight.com/cpi/ctaf/d ... mber=92349
Buy it and thank me later
Posted: Wed Oct 22, 2008 10:36 pm
by Dac
i have an air impact and im still thinking of getting an electric one.
Posted: Thu Oct 23, 2008 10:18 am
by noiseguy
Air or electric will strip threads if you're not careful. This is more a matter of what the gun is rated at. Both mine will run to 200 ft-lbs; I dial the air gun back to minimum for anything on the scoot and haven't had a problem yet.
Posted: Thu Oct 23, 2008 3:53 pm
If you mostly are working on smaller stuff, take a look at 3/8" butterfly style air impact wrenches. Around 75 to 100 ft/lbs max, the 3/8" drive will get you into sockets that fit smaller sized bolt heads. You can set the wrench to a lower approx torque than a 1/2 drive to protect the smaller fasteners. 3/8 gets the auto valve covers, oil & trans pan, timing belt cover etc.. plus the yard equipment and scooters. It was also great for installing 2 1/2" lag bolts when rebuilding our entry way stairs.
If that fits your type of work, you could cover both bases with a good quality 3/8 drive, and a lower cost 1/2.
Posted: Fri Oct 24, 2008 3:29 am
by maddog
it all depends how cheap you are and what cheap parts you buy
thanks toast
Posted: Mon Oct 27, 2008 2:07 pm
by paulbrown137
I picked up that impact wrench you recommended and it was on sale for $19.99. Darn good deal. considering it will probably only be used for the spree, it should be all that I need.
Its been a while since I've been to the local Harbor Freight. Man that place is fun. Even though some of the tools they sell look pretty cheap, they have everything and is a Man's man place to hang out.
I also got a two pairs of work gloves (1 leather, 1 canvas), 2 packs of shop rags, 1 package of small wire zip ties, 1 package of large ones, an assorted pack of shrink tube, 75' of poly rope, and probably something else i'm forgetting.
bill was $40
Posted: Tue Oct 28, 2008 4:18 am
by veedubh20
12v impact makita gun still going and had for over 2yrs .
