Would this work?
Aero Fifty
Would this work?
I have a 85 Aero 50 and is suffering from some cold start problems. I'm pretty sure the bystarter is bad because if you manually choke the engine (cover the air intake) it'll start right up. A bystarter costs about $50 bucks and I see some manual choke carbs on eBay for around $30 bucks. Can I just throw one of these carbs on my aero and run it?
http://cgi.ebay.com/ebaymot........itemZ220294908128
*also will I get any performance gains from running a larger carb?
Can you run the other carb? Yes. Will it give you any performance gains? Not likely. In fact over carburation (too big a carb) is the biggest hop up mistake made and usually causes a loss of performance, especially low in performance which is where these scoots suffer the worst to start with.
The problem with those carbs is that they are chinese (mainland) clones and quality is an issue. They are typically nowhere near as reliable as the Keihins used by Honda.
Tuners typically use flatslide Mikunis, Keihins (the real ones), or OKOs, but then they require a manifold change and are more expensive.
You're also going to have to mess with the jetting.
Clive.
Clive.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
Aero Fifty
Any idea how big the stock Aero carb is? I really would just like to ditch the auto bystarter all together and go with a simple manual choke. The auction I linked to was for a 24mm Mikuni carb. Also I was planning to install a big bore kit in the future and was wondering what size carbs are you guys running with a big bore kit?
Despite what is molded onto the carb body I still maintain that it is made in mainland china, so you have my warning.Aero Fifty wrote:The auction I linked to was for a 24mm Mikuni carb.
Stock engines are usually replaced with a 19mm carb, big bores with 21 or 24mm, and strokers with 28 to 30mm.
I think the original was 17mm, but not sure.
Clive.
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
dont buy china -made carb used less!
if you like a good runnin carb!! buy real Dellorto phbg, Keihin pwk carb and mikuni vm 18mm. How that.
cant go wrong on anytime.
you better off buy a dio moto and slap in
not aero 50 or 87 motor.
- scooterwerx
hmmm a genuine mikuni for 31$? im skeptical
please dont buy garbage china carbs from ebay. they are garbage. they are made out of god knows what kind of terrible pot metal, the seals are frail and dont really seal, and their manufacturing process must involve some sort of antique circus equipment, because its a joke. i learned my lesson the hard way! they are not even worth the low low price. if you really want one, i will give you mine. im serious. www.50cc.eu has all sorts of carbs for very good prices, i got a 21mm arreche for 130 bucks. the china carb leaked, ran inconsistently, never started well. 21mm arreche fires up everytime, fisrt try, runs like a scalded dog....i guess you get what you pay for.
- scooterwerx
On the website www.50cc.eu I see the Dio and EliteLX listed under Honda. Is the EliteLX an SE50 by chance?
most web shops are very outdated. Those also in Europe. But if they still have all that stuff, they ship, and the prices in USD isnt bad, you could get a carb, exhaust, bore kit, gears (look they have gears listed too)
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
- scooterwerx
NO S***?!?!?!?!scooterwerx wrote:50cc.eu is badass! i ordered a carb from them and it was here in less than a week! their website is very current, and the guy who runs it, marcel dekker, is a nice dude. they have all sorts of stuff for nb50/se50, just look up honda vision....
DUDE! thats awesome!
because that place has pipes, gears, bore kits, and all sorts of stuff for the SE50. Where are you located ScooterWerx? How much was your order?
