gear ratio
Posted: Fri Oct 31, 2008 7:31 pm
by evilone
ratio 16-32. Anyone know what that equals when converting? For example 9:1 etc.
I'm guessing 16 teeth small gear and 32 teeth big gear. I want to order some but my ratio choices are:
18-42
16-32
and 16-41
So my question is...what ratio would be close to 9:1?
Posted: Fri Oct 31, 2008 7:34 pm
by evilone
I think I figured that one out. Anyone know how many teeth are on the small and large dio gears with 9:1 ratio?
Posted: Sat Nov 01, 2008 8:51 pm
by tru72
im assuming its for a "S" af/16 motor
18-42 8.1
16-32 7.1
16-41 8.9
Posted: Sun Nov 02, 2008 5:05 pm
by evilone
Thanks tru72. It's an 87 se50 if that's the af/16. Would af/16 be stamped on motor somewhere or on a tag?
Posted: Sun Nov 02, 2008 6:12 pm
tru72 wrote:im assuming its for a "S" af/16 motor
18-42 8.1
16-32 7.1
16-41 8.9
There must be additional gear reduction somewhere else, as those tooth numbers are no where near those ratios.
18-42 = 2.33 : 1
16-32 = 2.00 : 1
16-41 = 2.5625 : 1
Posted: Sun Nov 02, 2008 6:27 pm
by Kenny_McCormic
an elite rear end has 4 gears on 3 shafts.
Posted: Sun Nov 02, 2008 6:47 pm
by evilone
the 9:1 gears for the dio are 16-42.
Posted: Mon Nov 03, 2008 1:56 am
by tru72
lol try 3.5 in your figuring
42 divided into 16 = 2.625
2625 x 3.5 = 9.1875
Posted: Mon Nov 03, 2008 2:17 am
tru72 wrote:lol try 3.5 in your figuring
2625 x 3.5 = 9.1875
Like I said there had to be another set of gears to get thouse final ratios.
Posted: Mon Nov 03, 2008 10:43 am
by Dac
hey Bear45-70, anyway i can get you to cut down the size of your sig. ? its a cool picture but its big for a signature.
Maybe you could go with something like,
Posted: Mon Nov 03, 2008 11:11 am
Dac, Done. I didn't know it was a problem, sorry.
