Engine or Clutch Noise
Posted: Mon Nov 03, 2008 9:54 am
Hi all
Just bought another scoot. Bike is complete all the electrics work, battery shot, wouldn't start even with a jump.When I opened the side cover I laughed . Had a nice petcock with on/off lever but the gas line went into the vacum port. Cleaned the carb good, replaced the petcock, set carb adjustments to specs, sucked new gas into carb, jumped started it and started right up. Heres the problem, idles good , revs good. made a make shift air filter until I get one from the dealership but sounds like there's rocks inside the engine. Don't think its an engine noise because when I rev it the engine sounds proper. I'm thinking it's clutch related although it seems to take off pretty good. Still I'm phys"d I did everything by the book and she started right up. Any ides what my noise may be.I also noticed the noise when I push the kick start and when I shut it down it seems to shut down pretty abruptly. thanks zeolig
