SB50p rebuild questions
SpyderMike
Post by SpyderMike »
i have an 88 SB50p and used the search to the best of my ability
my plan is to rebuild it this winter
1) replace the bearings on the crank (there not spinning smooth)
2) open up my intake manifold (i read no other mods needed to do this)
3) replace any other bearings that dont spin smooth
4) other stuff that i dont really have questions on
ok... now for the Q's
do i NEED that special tool for taking the stator off my crankshaft?
if no, what do i use?
do i need the special tool for splitting the case?
smoothing out my intake wont hurt anything right?
should i use OEM honda bearings? or get better quality high speed bearings from a bearing dealer here in town?
is a Port/Polish wort my effort?
can i reuse my oil seals? like the ones in the final drive, or should i buy new ones?
thanks in advance for any help you fine people here can give me and im sure ill have more Q's as the winter goes on
Post by Kenny_McCormic »
SB is already opened up, more s than a spree mani can be opened. If your pulling a seal replace it. For the price of a full tear down and rebuild you might want to look into a DIO or SE50 swap.
SpyderMike
Kenny_McCormic wrote:SB is already opened up, more s than a spree mani can be opened. If your pulling a seal replace it. For the price of a full tear down and rebuild you might want to look into a DIO or SE50 swap.
would i gain anything from the swap with out any upgrades?
Dac
Post by Dac »
an SE50 or a dio both do about 35mph stock. with amazing take off.
on a light frame like an sb50, i would say 40mph. But! with a dio motor, for $110 you can do all of 50mph. Speed comes cheap with those motors.
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
SpyderMike
Dac wrote:an SE50 or a dio both do about 35mph stock. with amazing take off.
from what ive seen by basicly living on ebay motors
DIO motors are really hard to come by, and the ones ive seen are like a bare motor
how much stuff from my sb will bolt up to a dio?
is buying a 88 SE50 motor even worth it?
tonrogs
Post by tonrogs »
I have an 87 SE50p motor that I could sell. I was looking for about $100 shipped. Make me an offer. It was running when it was removed. Things missing are the carb and the fan.
The SE50 motor has limited upgrades while the Dio motor you can do almost anything you want to do to it.
Due to newly found European parts connections the SE50 can be made just as quick for not much more.
SpyderMike
is it a direct bolt in on the sb50?
and care to share the parts connection?
tonrogs
Post by tonrogs »
Where is this site? Or contact info for SE50 parts. Thanks
devenex
Post by devenex »
http://www.hondaspree.net/phpBB2/viewtopic.php?t=7486
Thats the thread where all this is going on.
1986 Spree w/ '87 SE50 motor
