Changed #68 jet to #65 - still runs poorly
nelly
Post by nelly »
My #65 jet came in last night, swaped it out for the #68 that the spree came with but unfortunately, no difference. With the 65 in and the air box top screwed and clipped in tight, there's no power to the Spree. It runs, just no power.
But, if I loosen the airbox lid so there's just a little space showing, the Spree runs great and I can tear up and down the street @ 50km/hr.
Any other suggestions on what I'd need to check so I can close up the airbox and still have her run with power? Not a big deal since I can at least ride it, just curious what the problem could be.
Thanks everyone,
Steve
ferchja
Post by ferchja »
You may still be running to rich. Fuel could be coming from the bystarter and therefore giving you crappy performance until you lean out the mixture by letting more air in.
Could also be a bad/clogged air filter and or clogged inlet tubes on the airbox.
Jeremy Ferch
nelly
Post by nelly »
I'm not doing any damage am I running with the air box open a crack? There's no smoke coming out or anything, so I'll probably just ride it as is....
Steve
Do a plug chop to see how that looks. In tech docs.
MySpree
Post by MySpree »
i know what it is. this happend to me. just so happed i was just trying to ride it over to my freinds and happed out that my muffler bolts came loose and it got all its power back. but if thats not the preblem then your reed seat bent or reeds are just bad. 8)
MySpree
Post by MySpree »
in other words ur muffler is clogged or your reeds and reed seat is bent
