How to re-surface the carb needle valve at carb body
The home of the FAQs and all the things you need to know to fix your Spree / Elite, outside the service manuals
Moderator: FAQ Moderator
How to re-surface the carb needle valve at carb body. Thanks to Wheelman-111 and Kenny for this tip.
Honda-san sternly admonishes to "replace the float needle and seat 'as a set'...". Huh? The "seat" is the gritty aluminum carb casting!
I used a sage Forum member's advice and tested the seal by lifting the float while blowing into the fuel fitting. It leaked unless I pushed pretty hard on the float - harder than I think the buoyancy of the float would apply.
K McC suggested polishing the seat area with a Q-Tip and some polishing compound. Not having said compound handy, I looked around for a mildly abrasive diamatomatous paste and came up with...
Colgate! I needed to strip a little cotton off the Q-Tip so it would reach the bottom of the float needle seat. I lapped for a minute or 2 and voila! A shiny new seat for the cone-shaped point! All this AND cavity protection!
A quick spray-down with carb cleaner and a float tab adjustment later: airtight seal!
Sorry no pics of the process. BlackBerry phone photos are unable to capture the grandeur of this small victory.
The bet will be hedged by a second, hopefully functional, new vacuum petcock when it arrives. Honda-san; I got yer needle seat seat right here!
