idle problems
Posted: Tue Dec 23, 2008 10:30 pm
I have a 88 elite lx, with a top end rebuild and cleaned carb.
I have to kickstart it with the key on, but with the run switch off. like 5 times and then turn the run switch on, for it to start, once it starts it runs fast on the kickstand for a couple of minutes, then idles fine. It runs smooth, but then it slowly dies out if i do not keep the throttle going. After it shuts down, i have to wait about 15 minutes before i have to go thru the same process to get it started.
It sounds like the idle is smooth, should I adjust the air mixture to fine tune it to keep it at idle or is it a possible air filter problem?
