that looks cool but you really should do this...
For a few reasons...
1- to long of a downtube before the expansion chamber is a bad thing you loose the good efect of it. So shorting it down some would do good.
2- it wont stick out quiet as far so it will look better
3- Welding it will seal everything off better and it will perform better.
I also see a small flaw with the way the looks right now. You stock the pipe in the downtube and not over the down tube.
Now, Note- The red arrows point to where there is drag. Slowing exhaust flow and giving you less performance.
After, no points for drag and better flow.
