headlight/85 spree
Posted: Fri Aug 05, 2005 6:23 pm
by generalsecord
headlight works when its out of the spree i plug it back in ,turn on the switch nothing.have checked all wires leading to and from the spree.the tail lights,the brake lite,the horn all working.any way of hooking it directly to another live circuit,or is it in the switch
thanks george
Posted: Fri Aug 05, 2005 6:26 pm
by vette76
only works when bike is running.
headlight
Posted: Fri Aug 05, 2005 6:35 pm
by generalsecord
ok the bike is running, still no head light
Posted: Fri Aug 05, 2005 11:33 pm
by ferchja
if its the switch, test for continutity and you will know. ALso theck for voltage.
headlight/85 spree
Posted: Sat Aug 06, 2005 8:16 am
by generalsecord
how do you check for continuty give me a simple way
thanks
george
Posted: Sat Aug 06, 2005 1:57 pm
by MySpree
when i got my scooter the head light didnt work, but when i took it out and put it to the battery it shined, well my prob was a badground, the green wires are the grounds make sure all of them are attaches or if the wire didnt rip, also my hi lo lights swich doent work, so when i go lo, it turns of and when i go high it goes realllllllly bright, but i like it that way,
headlight/85 spree
Posted: Sat Aug 06, 2005 6:10 pm
by generalsecord
ok man i will ckeck it out i wii let you know what i found out
later
george
