u.s. to dio trans conversion
maddog
Post by maddog »
I have posted in the past how easy it is to convert your stock elite-s trans to a true japan dio, don't know why the michigan boyz didn't jump on this as the only restriction the japan dio had was the cdi because the u.s. engine block was milled smaller, got my parts from vy cycles a long time ago, post if you are interested, dio trick of the trade= shhheee don't tell nobody :lol:
Dac
Post by Dac »
ok, ill bite.
How?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
scooterwerx
Post by scooterwerx »
does this have anything to do with the OKO OEM Dio style clutch assembly? they have the JDM rear pulley as well?
steffen707
Post by steffen707 »
I wanna know! I almost bought a dio engine from the U.K. Till I foiund out shipping was 130 british pounds. Ugh! I want the bigger rear pulley!
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
Dac
Post by Dac »
jonsteffen wrote:I wanna know! I almost bought a dio engine from the U.K. Till I foiund out shipping was 130 british pounds. Ugh! I want the bigger rear pulley!
from what i understand you can set up a "zx" trans thats the same as the real japanese dio. but overall the American one is better because its easier to find parts and tune.
burnt_toast
Post by burnt_toast »
exactly right.
projects galore :nerd:
steffen707
What is a "ZX" trans?
And i'm fine with keeping my engine, trans castings, All I want is the rear pulley. More acceleration please!
87 Honda Spree,
XX Yamaha YSR50
Dac
Post by Dac »
you know your clutch is also a pulley system? it opens and closes just like the front pulley.
The ZX trans is fancy talk for front clutch and rear pulley. However its harder to tune and harder to find parts. you better off keeping the system you have now and just upgrading the pulley.
steffen707
WOAH, wait, DIO trans had the clutch in the front and the variator in the rear?
Yeah I don't need that per say, but I do want the bigger pulley.
87 Honda Spree,
XX Yamaha YSR50
Dac
Post by Dac »
jonsteffen wrote:WOAH, wait, DIO trans had the clutch in the front and the variator in the rear?
im not 100% on that, but i know its really weird.
if you just want a bigger pulley you can get that no problem. VTcycles has good ones for a very reasonable price.
steffen707
wait, they have aftermarket rear pulleys at vtcycles? The pulley that is connected to the clutch?
I thought all they had were front pulley variators?
87 Honda Spree,
XX Yamaha YSR50
burnt_toast
what the hah this is misleading
all "zx trans" is a larger REAR pulley/dio style
if you want acceleration tune for it! stock rear pulley is plenty for this, run stiff springs light rollers and big bore, nets you all the accel you'd want garanz :wink:
steffen707
No, I want all the accel possible. This means jap dio rear pulley and different belt and an upgraded torque drive.
If they didn't put them on hopped up race scooters, I wouldn't buy one, but I don't care about going over 50mph. I want to zip to 50mph as fast as possible.
87 Honda Spree,
XX Yamaha YSR50
evilone
Post by evilone »
Hey, that's what i want too, but a top speed of 55!! :D But i'm not spending a ton of $ to do it so i'm just doing the basics.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
burnt_toast
jonsteffen wrote:No, I want all the accel possible. This means jap dio rear pulley and different belt and an upgraded torque drive.
125cc stroker + stock gearing ;)
all the accel you'd ever need garanz haha
