Aero, exhausted
- scooterwerx
Aero, exhausted
Well, today the UPS man brought a large box, within was a Leo Vince SP3. Ho-lee-smokes. Gotta get back to work since i wasted all morning installing and tuning!!! Good thing i work for myself or Id be FIRED!!! hahaha Pics and more details later....
Aero Owners Worldwide Unite in Hating Werx
Glad you got the pipe.
Sort of...
Actually there's no sense prevaricating about the bush;
I hate you!
So it fits? Could you include the box in your pictures with model numbers, anything searchable?
Thanks,
Guy
Sort of...
I hate you!
Thanks,
Guy
- steffen707
I want to see it too. As well as performance comparisson. Do you have a stock pipe now, or is this an upgrade to an upgrade?
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
XX Yamaha YSR50
- scooterwerx
At first i was underwhelmed by the pipe. The fit and finish isnt the greatest, and you have to grind out a restrictor in the header right off the bat! I guess its to meet legal requirements in Europe...it also rubs the rear tire and had to be shimmed with some washers.
The noise level is barely louder than stock. First i ran it with everything setup as it was. low end power was turd-y, mid range so-so. at about 35 it picked up and pulled hard all the way to 8800 rpm. Leo Vinci includes rollers, so i installed them. I had my polini rollers at 8.7g, these were 6. it revved out to full tilt and went slower than my elite E! I changed the contra spring back to stock, and it is golden. now i have a malossi red contra spring for sale! adjusted the clutch to begin engaging at 4500, and it runs like a raped ape! amazing roll on power, wheelies at 25mph easy. pulls hard all the way from 0 to top speed, havent been able to acccurately measure top speed, but judging from how far the needle goes, id say at least 5mph more top speed, maybe more, due to the fact that it picked up almost 1K rpm. its definetly 60mph plus. throttle response is great, the jetting is very close, im going to pick up a new plug for more testing. its crisp and responsive throughout the rpm range, so its close. I want more now! My next build is going to be elite E with nb/se50 engine, polini kit, etc. I would like to experiment with a real expansion chamber, just gotta find time! Just this mild exhaust made a night and day difference, if you find one of these, get it! its worth it! after shipping I paid a tad over 150, daywot had one a year ago for 175.
LV SP3
Nicely done.!
Nicely done.!
That thing looks like an expansion chamber, and from the tuning you did it sounds like it's acting like one too. What exactly is inside?
- scooterwerx
It's What's Inside that Counts
Thanks for making my search for the elusive NB50 Aftermarket pipe a little easier. No need to break out the coat hanger or buy an expensive flexible proctoscope;
http://www.sitogroup.com/servlet/page?_ ... tmp=121988
This is another SP3 pipe for a different application, but the innards should be the same. There's supposed to be a good amount of glass packing, too, so coat-hanger explorations won't work.
- steffen707
So did you end up liking the pipe because you tuned the transmission to a different rpm that better suited the exhaust?scooterwerx wrote: At first i was underwhelmed by the pipe. The fit and finish isnt the greatest, and you have to grind out a restrictor in the header right off the bat! I guess its to meet legal requirements in Europe...it also rubs the rear tire and had to be shimmed with some washers.
87 Honda Spree,
XX Yamaha YSR50
XX Yamaha YSR50
- scooterwerx
- steffen707
how does it compare to a PG long or a technigas R?
Those seem to be 2 popular pipes I hear a lot about.
87 Honda Spree,
XX Yamaha YSR50
XX Yamaha YSR50
- scooterwerx
i dont know much about those two, this is the only one ive had direct experience with. the PG long seems more like an all out performance pipe, killer top end, with sacrificial bottom end power, for huge stroker motors and such, and the technigas seems like a more all-around pipe, for smaller engine sizes.
from that there picture, wheelman, it looks as if there is no baffle cone in this pipe, it looks like a straight megaphone, all diffuser! how weird...
Baffling!
I believe you said you ground out that baffle cone before you even installed that thing!
I still haven't forgiven you for scoring that fine pipe ya know...
- scooterwerx
