burnt_toast
Posts: 3469 Joined: Sat Jul 31, 2004 8:00 pm
Post
by burnt_toast » Mon Jan 19, 2009 9:43 pm
just saw it on ebay, what do you guys think?
honda dio 65cc cyl kit
wish i could see base view to compare ports but just eyeballing looks like it should fit up to 94+ elite cases, cheap kit if so!
*EDIT*
Just found similar kit in Australia
HERE
And looking at base gasket looks like boost port is much larger, dang US elites and their restricted boost port
projects galore
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Mon Jan 19, 2009 10:06 pm
Looks like a good deal.
steffen707
Posts: 910 Joined: Wed Aug 13, 2008 12:41 am
Post
by steffen707 » Mon Jan 19, 2009 10:18 pm
Where can I read what the boost port is and how it works?
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
burnt_toast
Post
by burnt_toast » Mon Jan 19, 2009 10:43 pm
hah but who wants to do that kenny
you need to split cases to cut the boost port properly that way, and doing so isn't appealing on a budget build like with these 65cc cylinders
http://books.google.com/books?id=A9KsF2 ... t#PPA56,M1
pg56, see the third central port, that is your boost port our elites have that and thats whats in question here
projects galore
timcat
Posts: 434 Joined: Mon Dec 15, 2008 1:56 am
Post
by timcat » Tue Jan 20, 2009 12:49 am
would this fit on my spree?
burnt_toast
Post
by burnt_toast » Tue Jan 20, 2009 1:01 am
timcat wrote: would this fit on my spree?
yes, its bolt on power
projects galore
steffen707
Post
by steffen707 » Tue Jan 20, 2009 8:58 am
yeah but it's only 15cc more. Why not get a bigger bore kit?
87 Honda Spree,
XX Yamaha YSR50
burnt_toast
Post
by burnt_toast » Tue Jan 20, 2009 10:40 am
jonsteffen wrote: yeah but it's only 15cc more. Why not get a bigger bore kit?
different goals for different strokes
i have my fast bikes, this would be for a budget build that doesn't need to go much faster
BUT just to clarify this kit wont fit any US honda scoot without modification. boost port is different and piston takes 12mm pin!
projects galore
timcat
Post
by timcat » Tue Jan 20, 2009 11:39 am
ok so i could just bolt this on and go on a spree no major surgery ? i may buy it to see what ir does its rather low cost
scooterwerx
Posts: 892 Joined: Tue Oct 07, 2008 11:43 pm
Post
by scooterwerx » Tue Jan 20, 2009 11:44 am
i think the boost ports on a dio would sit outside of the sealing surface on a spree, i dont think it would seal at all!
i opened up my boost port by roughing it out with the dremel and a die grinder with rotary burr, then cleaned it up it a small file and curved piece of wood with sandpaper 2sided taped to it, to get the radius right. with both halves together it makes it easy to match them perfectly!
veedubh20
Posts: 1667 Joined: Sat Dec 31, 2005 7:00 pm
Post
by veedubh20 » Tue Jan 20, 2009 12:00 pm
burnt_toast wrote: hah but who wants to do that kenny
+1 malossi cast 72cc , need to split case and match boost port and much better than 65cc taiwan bore/ polini corsa.
I heard young boy on forum hawaii. rode a dd50 w/ polini corsa bore and taiwan stock crank snap by sym
steffen707
Post
by steffen707 » Tue Jan 20, 2009 1:46 pm
Lol, I still don't see any info about "boost port" on page 56 of that book. Am I retarded?
87 Honda Spree,
XX Yamaha YSR50
Post
by Kenny_McCormic » Tue Jan 20, 2009 4:28 pm
Tim: he is kidding there is no bolt on spree kit. Im working on that, if I ever have $100 floating around.
timcat
Post
by timcat » Tue Jan 20, 2009 9:39 pm
kenny incoming pm
burnt_toast
Post
by burnt_toast » Tue Jan 20, 2009 9:46 pm
Kenny_McCormic wrote: Tim: he is kidding there is no bolt on spree kit. Im working on that, if I ever have $100 floating around.
hah I do believe I was!
Tim we have ALL mentioned there are NO big bore kits available for a Spree, SEVERAL times, I was joking here.
projects galore
