Help cant get timing stator thing off
Posted: Tue Jan 27, 2009 12:17 pm
by espears
Picked up an 86 spree but needs new piston and sleeve, now i think something is caught in the flywheel? The thing that is attatched to the piston rod that rotates to push the piston up and down. It can rotate but sometimes gets stuck, so i think some debris might be in there and im trying to get it out. I have to split not the crankcase but the other case and get in there to clean it. How do i get off the timing thing that is covering the stator coils??
Anyone know?
Thanks
Posted: Tue Jan 27, 2009 2:06 pm
I think you are talking about getting the flywheel off.
Here's a thread discussing tools for removal
http://www.hondaspree.net/phpBB2/viewto ... eel+puller
Posted: Tue Jan 27, 2009 3:54 pm
by Kenny_McCormic
He is rtalking about the crankshaft, The cases will have to be split, there is probably a chunk O piston in there.
