Stator troubles
Salvatore
Stator troubles
Post by Salvatore »
Hello,
While working on my Aero i accidentily severed one wire in on one of the "spools" on the stator by spinning the metal cover with the fan screws too far in. I havent tried seeing if it still works because i was wondering what i could do to fix it while its still apart and out of the frame. Can the wire be soldered or can i buy some wire and rewrap the stator. I looked online and at Babbitts its $80+ and unavailable.
Any advice would be greatly appreciated
1981 Honda C70
1985 Honda Aero50
Ouch! yeah, its easy to have that accident, only happens once!
In my opinion its easier to get a used stator and swap it out. Check eBay and such, I've got them for under $30.
Maybe you can scape the wire ends and solder a bridge over the severed wire. Use a hot iron, and do it quickly. Hot iron will let less heat spread out into the wire and coil, limiting damage potential. For a small break like that you can use a thinner gauge wire for the bridge, it should make soldering easier.
Downside: The coils are impregnated with something - varnish? That will melt smoke & smell bad - as can the insulation on the wire at soldering temperatures. You could end up with a shorted coil immediately or a failure after the repair. I recall coil wire insulation is 'designed' to melt at soldering temp. Production shops used to dip cut wire ends into a solder pot to strip the insulation. Much faster than scraping or sanding the varnish off.
