Using my caliper I measure the width of one edge to be about 2 millimeters. It's hard ot measure the diameter because the oring is flexible but according to my caliper it is just at 25mm.
Here is the issue.
The width from side to side and the depth are different. I assume this is because it has been squished in there for 24 years.
Here is a little picture to help you understand.
My options from Babbitts Sports are
O-RING (20.6X1.9) (Honda Code 1100585)
O-RING (21.9X2) (NOK) (Honda Code 1915339)
O-RING (22X2) (ARAI) (Honda Code 1915321)
O-RING (18X1.9) (Honda Code 1176700)
I also have a service manual. Maybe I should check there first. I'll edit if I find anything in service manual.
