Hello All,
I have an 84 aero nb50m and I have cleaned and cleaned the carb.
It will only start on starting fluid and I can keep her running with little
squirts of gasoline into the carb. I am getting fuel to the bowl and I
have replaced the float valve. New petcock and am dumbfounded.
Good spark, new plug new cap and new fuel filter.
When I give it throttle nothing happens! It just races and dies
until all of the starting fluid is spent.
Any help would be appreciated.
al
84 aero 50 only starts on starter fluid
80 and 49cc bicycles............3 = 2
2 Lifan 150cc scoots
1 86 honda spree...
1 84 Honda Aero NB50m
1 86 honda spree...
so your carb is super clean, ever try checking your final drive pulley, it 2 pins that ride an "s" groove, if you don't grease them every yr. if the pins wear out leaving you're done. remove the center spring and look for dimples on the sleeve, if you see any your rear pulley is shot
1984 nb50m
turned out to be the throttle cable was not allowing the needle to seat
all the way in.................running excellent now.
thank you for the help. carb was clean after all.
al
al
1 86 honda spree...
1 86 honda spree...
