Quick Question
hollister_boy
- BMX
Quick Question
So.
I want to remove my exhaust off of my 84 Spreeee.
To paint it.
Only problem is that i think its never been removed before,
so its like inpossible to take off, should i break the bolts are replace them?
Or try something else?
To paint it.
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
Breakin' Bolts
A long 10mm socket is the correct tool to use, provided they are not hopelessly rusted in situ. If you are patient, you may be able to loosen them enough to slip the flange hangers off the studs without breaking them. I'd start by taking the muffler bracket bolts off and seeing if it'll wiggle just a little. Spray liberally with penetrating oil and see if you can get them to move at all. You can alternate loosey-tighty sometimes to get the oil down into the threads. Use a short-handled ratchet and not a lot of force. Sometimes the studs break, which is enough of a pain in the behind. Sometimes the port cracks, which is worse...
hollister_boy
- BMX
Thank you, I will go try this now.
hopefully it will come off with out any trouble,
if not do u know if it is possible to paint the exhaust while still
on the scoot?
on the scoot?
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
Paintin' Pipe
It's possible, but only if you don't care how your pipe (and the rest of the scooter) looks when you're done. C'mon, take it off. You know you want to...
hollister_boy
- BMX
.........ehhh
I want to but i tink im beyond that point now.
Seams i just tried a shore 10mm Rachet, and sadly it wouldn't come off still,
and stipped.. so now i guess i must clean it up and paint it on the scoot.
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
tape a bunch of newspaper to motor and body unless you want the overspray! Hollisterboy huh? Are you a hollister? Just wondering cuz my moms side of the family are Hollisters.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
hollister_boy
- BMX
no
hollister_boy was something random i came up for a nickname on the fourms,
it came from the store hollister lol
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
hollister_boy
- BMX
Studs
It's not a lost cause. If you can, install a second 10mm nut (thread diameter is 6mm, I believe) and snug it down tight over the existing nut. Apply a lick of heat to the area around the studs with a propane torch., then thread on the long socket over both and the stud should spin out of the head - hopefully you'll exercise discretion with that super-human strength and not break it off. It really is easier with heat. You can probably even re-use the studs with the doubled nuts to reattach once you've got the pipe painted. If they do break, search broken exhaust studs in Tech Help for more information on extracting them.
