? on 87 elite
eight08boy
? on 87 elite
Post by eight08boy »
does any one know how long and wut size the motor mount bolt is
Gjino Kanahele
U asking cherry price u better have cherry s***
bakaracer
Post by bakaracer »
the one that mounts the motor to the motor mount is 8mmx145mm and the bolt for the mount to the frame is 10mmx140mm
Honda Elite SE50 - 1987
95800-10140-00 - 10X140 - Frame to link
90021-ZB0-000 - 8X145 - Engine to link
edit - bakaracer clearly had it first - was searching while watching the tube...
eight08boy
ok does any one know where i can get them
Gjino Kanahele
DJPhatman
Re: ..
Post by DJPhatman »
eight08boy wrote:ok does any one know where i can get them
Any decent hardware store should have them, or can get them for you. Be sure to get new nylon insert locking nuts, or nyloks, to complete the bolt.
bakaracer
Post by bakaracer »
hardware stores mainly carry sae bolts and in that length is a special order item. goto babbits online and order there.
eight08boy
thanks cuz i whent to the hardware store and there biggest bolt where way to small
Gjino Kanahele
bakaracer
Post by bakaracer »
use the correct size bolt.if not your going to have engine vibration and wear out the motor mount and engine bushing eyelet from the bolt being just a little to small.
Size Matters, But Hardness Matters More
Size Matters, But Hardness Matters More. :oops:
Let me rephrase...
Getting the correct Size bolt is only half the solution. Bolts are made of several different grades of steel, each with its own particular characteristics. Softer steel is weaker but more resistant to cracking and breakage. Harder grades of steel is stronger but more brittle and sensitive to point-loading, say in the gap between the bracket and engine case.
Just because it fits doesn't mean it's right or safe in your application. Think about what that bolt does. Going around a corner at 40MPH is not a good time for a cheap substitute bolt to reveal its inadequacy. Get the Honda part.
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
honda uses class 8 bolts i believe. The bolt can be recognized by the 5 dashes on the head when you buy them. The length of that bolt in MM is not easy to find and you will be extremely lucky to find it in a local hardware store. It is more than likely a special order from a nut and bolt shop. Expect to pay alot.
