Cannot Keep Running
Posted: Sun Sep 19, 2004 7:33 am
by gearmanz
I can get Spree to start by spraying starter fluid into air intake, then kick starting it. It will run for 10-15 seceonds and quit. I drained and replaced gas & oil, new plug and cleaned carb, still no change. Any suggestions?
Thank You!
Posted: Sun Sep 19, 2004 11:58 am
by noiseguy
Take it easy on the starting fluid, you can easily melt the piston on these.
If it won't start the idle jet's not clean. Try pulling the choke partially out,remove screws and pull up, making sure not to pull it out past the o-ring. If it runs then the idle circuit still isn't clean. If the idle jet is still blocked try using a toothpick to clean.
Won't stay running
Posted: Sun Sep 19, 2004 7:09 pm
by Jerry
Check the vacuum shut off valve too.
Posted: Sun Sep 19, 2004 8:56 pm
by noiseguy
I assume you checked to see if there's gas in the carb by opening the carb bowl drain. How's the tank for rust?
