Gas Typeishh Question
hollister_boy
Post by hollister_boy »
Im having problems with my gas gauge on my new scooter.
Can come one tell me where to check the connections?
It never shows it fully filled only about 25% full.
thanks
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
burnt_toast
Post by burnt_toast »
chinese scooter?
common problem I've seen is float that is attached to gas sender gets stuck inside the tank and can't move, not giving you an accurate reading.
get to the gas tank and remove the fuel sender, then place back in but at a different angle, should do the trick if its a brand new scoot
projects galore :nerd:
hollister_boy
thanks.
i will try when i get back home.
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
hollister_boy
Oh..
And by the way...Yeah its a Chinese scooter,
Preatty nice.
Having no problems with it so far except for the fuel thing.
its a Wildfire 50cc 2008.
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
hollister_boy
Solved
Yeah i solved it a while ago but am just now posting.
The gas float is attached to a metal bar,
then the metal bar is attached to a reader/sensor (whatever)
So.. where the metal float bar connects to the sensor, the weird and odd
Chinese ..thing was to tight, to i pryed and bent it a bit then retightened,
Problem solved.
Works great.
SPREE SPREEEEE
84
WHITE
LOTS OF MILES
50 cc's STOCK 33MPH
Wildfire
50 cc
WFH50-S2
45 MPH STOCK
