84 aero nb50m
Posted: Thu Mar 19, 2009 11:29 pm
by alvin
aloha,
Got a new carb for an 84 aero 50 and she still races....once I cover my hand on the carb she idles well..................new bistarter, petcock, *owner) plug, gas.
new air filter , cannot get her to idle properly, when I put on the rear
brake she does idle down.
thanks,
al
Posted: Fri Mar 20, 2009 12:24 am
by bakaracer
did you rejet the carb after putting the air filter on? also use carb clean and check for intake leak around the carb and intake manifold.
Posted: Fri Mar 20, 2009 10:03 am
by Johnny5
Yeah, definitely check the boot and don't underestimate a properly oiled filter. Mine for one was very particular with the air box setup. Sounds like shes just running a little rich.
Posted: Fri Mar 20, 2009 12:03 pm
by DJPhatman
alvin, you must have the air-box and proper filter in order to tune the carb. The engine is running away lean, thats why it slows down when he manually "chokes" it with his hand. these little engines need a restrictive intake, and a fairly restrictive exhaust to run properly. Change the balance, and you have to re-jet/tune to compensate.
1984 Honda NB50m new carb..........
Posted: Wed Mar 25, 2009 3:45 pm
by alvin
Replaced the air filter with an original from Honda. Found the needle
to be bent! Seller sent me a replacement needle and valve. The original
carb had 4 tubes this one has 5. Was told that has an extra breather tube
Should I block the extra tube?
Al
Rear Transmission Cover.
Posted: Wed Mar 25, 2009 4:23 pm
On the off chance you should ever need a good rear transmission cover, you can have mine - bought in error - for $10. I'll even ship it for that.
1984 honda aero nb50m
Posted: Sun Mar 29, 2009 8:36 pm
by alvin
OK so it turns out that the throttle cable was NOT letting the piston and
needle drop all the way down, therefore causing the engine to rev.
She runs and idles now and am happy to announce that I can ride
her finally. She does scoot right along too!
Thanks for all your help..
al
