performance parts?
Posted: Tue Mar 24, 2009 8:02 pm
by erog5188
Where can i find perofrmance parts for a 98 elite s. i have the clutch restrictor off i am looking for a pipe. any help? also if i add a regular say 50cc air filter will i need to do anything else to keep it running correctly?
Posted: Tue Mar 24, 2009 8:20 pm
by jesse1234
This thread has a ton of great websites where you can buy parts.
Have you derestricted the muffler yet? That makes a big difference, and doesn't cost anything....
Adding an air filter won't do much for performance, but you will probably need to upjet afterwords to compensate for how lean you'll be running
Posted: Tue Mar 24, 2009 8:54 pm
by burnt_toast
to clarify i think when yall say air filter you mean "open filter"
air filter is just drop in for stock airbox
can find performance parts from
www.vtcycles.com
and ebay check em out
Re: performance parts?
Posted: Tue Mar 24, 2009 9:17 pm
by bakaracer
erog5188 wrote:Where can i find perofrmance parts for a 98 elite s. i have the clutch restrictor off i am looking for a pipe. any help? also if i add a regular say 50cc air filter will i need to do anything else to keep it running correctly?
What kind of performance parts are you looking for and what speeds are you looking for?How much are you willing to spend?
Posted: Tue Mar 24, 2009 10:17 pm
by erog5188
i get like 40 out if it now and have not drilled the pipe. i am not looking to get big speed maybe 45 to keep up with my friends ruckus top end. but i dont want to lose my holeshot and accel. i will spend about 100 dollars maybe a little more
S Mods
Posted: Wed Mar 25, 2009 11:39 am
To your original question:
First remove your exhaust and ascertain that there is not a washer welded in there. If there is, a dremel tool or similar can remove it and your the main problem with output. Having de-restricted your stock pipe, a slightly larger main jet may be necessary. Look up your model/year at MrCycles.com and go to carburetor. Scrfoll down to part number 99101-0**0 . Your main jet size is represented by the **. A bigger jet will add a little more fuel to keep up with the increased volume of air the engine processes and keep it running correctly. With the exhaust so de-restricted and the engine breathing correct mixture, you should easily attain 35MPH. Your holeshot will only improve.
From there, if you purchase a Keli Variator ($40 at DayWOT eBay) instead of your de-restricted stock one, you may see 40MPH or more with that mod alone. No change in acceleration.
Should you decide to drop the airbox and install a UNI or K&N, you may need to jet up another size. It will make your bike a lot noisier. Do one thing at a time and reassess. Buying and installing a pile of parts all at once requires experience and a measure of good luck.
Posted: Wed Mar 25, 2009 1:31 pm
by ALOW1
erog5188 wrote:i get like 40 out if it now and have not drilled the pipe. i am not looking to get big speed maybe 45 to keep up with my friends ruckus top end. but i dont want to lose my holeshot and accel. i will spend about 100 dollars maybe a little more
40 Mph on a bone stock S
Posted: Wed Mar 25, 2009 5:19 pm
A Low One says:
Why the shocked look? My tired old Aero went 38 as a 50cc. Didn't stay that way for long, though...
Posted: Wed Mar 25, 2009 7:28 pm
by erog5188
yea i have gotten it to 42 but down hill i can get like 40 with the wind at my back no problem and it races to 35. are the jets hard to install?
Hard 2 Install?
Posted: Wed Mar 25, 2009 11:22 pm
Erog axes:
Not if you can operate a socket and a screwdriver. Look in the Tech section.
