Stripped splines on crankshaft
Posted: Wed Apr 01, 2009 12:41 pm
Well, my SA50 '89 made a horrible noise while I accelerated, ran fine home and then wouldn't start next time. Seems the outer pulley was loose and looking closer the splines on the crankshaft don't extend beyond the boss for the movable pulley. I guess the pulley worked loose and then stripped the splines good when I started it again.
I read another post where I think the guy just torqued down the nut with an impact and it worked ok which is going to be my first try. Will also put a second nut on to keep it on there as good as possible.
If that fails I guess I'll try to tighten it on good then put a few tack welds from the nut to the pulley and then from the nut to the shaft itself.
Hopefully method 1 will work though as I think that once it's started most of the pressure will be outward and not radial which would be more of starting and what the splines would be for.
Any suggestions?
Cheers,
CT
http://www.hondaspree.net/phpBB2/viewto ... crankshaft
out of focus picture to confuse you:
Any suggestions?
Cheers,
CT
