83 Aero throttle stuck wide open, please assist
Posted: Wed Apr 01, 2009 11:35 pm
So I have a 50cc honda 1983 aero/lead. Was driving around fine the other day, but I checked the throttle sleeve/jet/spring valve assembly that sits atop the carb and when i reinstalled it- The scooter wouldnt start.
So, I dropped a spot of gas in the cylinder, it started up, but instantly revved all the way up. Its seemingly stuck at wide open throttle, And I would like to believe its the cable, throttle sleeve or something but i manually pushed the throttle jet needle sleeve all the way down to where it should idle and no luck, still all the way open. I took it completely out, no change. Disconnected some vacuum lines, no change. So Im not exactly sure what it is. Ive hooked all the vacuum lines up correctly, cannot find any cracks or leaks, and have checked and re checked to the service manual the installation of the throttle valve and sleeve assembly.
Basically this is my only issue, and before, it started on the first try with the starter- everytime.
The only other issue I noticed is that before this happened I would be driving it on the road and it would never open up past 2/3 throttle. It would just sputter until I let off. Occasionally it would open up all the way.
