the problem i have is that there's a TON of resistance with the head on. if the piston is off, you can grab the starter gear and turn that just fine. with the cylinder and piston on there's some resistance, but, that makes sense because now you're moving some objects. however, when i put the head on and cranked everything down, suddenly there's a ton of resistance when the cylinder is near the top. possible it's while it's on the way down.
what's going on??
thanks guys
