i'd like to hear what injector oil brands folk here use or have used with good long tern results or any brands that resulted in problems. i've heard a few times not to use belray si-7 due to fouling issues.
regards
2 stroke injector oil question
- scooterwerx
- wikked_spree57
I've always used Castrol GTX snowmobile oil, says right on the case good for injectors OR premix. I switched up to Coastal TC-W3 one time and burnt up a Spree. Since then I ONLY use the Castrol or Honda GN-2. The GN-2 is the best you can get, but the closest place to get GN2 here is an hour away, I can get the Castrol GTX for $4 at Advance Auto Parts.
Similar to Scooterwerx's results, the Castrol has a rather sweet smell to it.
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned
- circusracer
- Goped
I run Amsoil two stroke injector oil. Seems to be just fine, I have used it since last spring, I now have three Sprees and run it in all three and it doesnt seem to foul the plug any. My son has a Kawasaki 85cc two stroke dirt bike so I already had a gallon of the oil, plus my friends use it in their oil injected snowmobiles.
Im not a huge religious pusher of Amsoil, its just a good buddy is a dealer and talked me into using it for my race car, and after a long hard season the engine always look great after the teardown, so the stuff works a bit better than Mobil-1.
84,85,86 sprees: Intake mod, drilled pipe, .020" milled 1985 head, dome piston, 2mm raised exhaust port, sb50 reeds, 34mph average.
