anybody run w/o a petcock? /thread size
cf_z
Post by cf_z »
is anyone around here running without the vacuum operated petcock?
mine is malfunctioning, and i am thinking about just running a straight line to the carb.
does anyone happen to know what size threads are coming off the tank (that the petcock attatches to?)
thanks
94 Elite SR.
PoliniCorsa+PGlong+28oko+8.44.1+KeliVariator+HiEnergyCoil+Pirrelis
=fast
Post by Kenny_McCormic »
If you go that way add an inline shutoff, or buy a on/off/reserve style motorcycle petcock.
cf_z
Post by cf_z »
is there really a need for it?
i mean ofcourse if i dump the bike the fuel will spill out, but other than that, theres no real reason right?
94 Elite SR.
=fast
CaptDan
Post by CaptDan »
cf_z wrote:is there really a need for it?
If you ask me (and you didn't) - there IS.
All things being equal, a healthy carb float and valve will keep the fuel from over-filling in the carb. But what if the float goes south? Then what?
Second, what happens when you try to remove the fuel line from the carb for cleaning or maintanence? No petcock? No stoppa da gas. :shock:
Petcocks are easily obtainable. Do as HondaSan envisioned, and get a working one for your scoot.
CaptDan>
circusracer
Post by circusracer »
I have found a great cure for myself for the malfunctioning petcock. First I went to the hardware store and bought some 3/16" id clear fuel line, a lawnmower type fuel filter with 1/4" barbs, a lawnmower type fuel shutoff with 1/4 " barbs, and one hose clamp. Total cost is around $10.00. The 3/16" line fits over the carb nicely but just a tad loose, that is what the hose clamp is for: the carb. First remove the petcock and take a small drill bit and insert it in the "fuel outlet" of the petcock and drill until the drillbit pokes thru into the main body of the petcock, now you have free flowing fuel with no worries of vacuum. Next reinstall the petcock (no need to worry about thread sizes or fittings) put about a 1 1/2" length of 3/16" clear fuel hose on the petcock, I didnt use a hose clamp here becasue there is no pressure to force a fuel leak and gravity takes the fuel down anyway. Next I took a heat gun to soften up the fuel hose to slide over the 1/4" barb of the fuel shutoff, push on as far as it goes. When the fuel hose cools down it makes a very tight seal, no need for hose clamp. Next step is add a couple more inches of hose to the fuel filter, once again heat gun method, then add hose to the carb.
Now you have free flowing gas on deman, no worries, with a fuel shut off for when you need to remove and clean the carb. I have this set up on all three of my sprees and works great, you never have to crank and crank after sitting for a while to get started.
84,85,86 sprees: Intake mod, drilled pipe, .020" milled 1985 head, dome piston, 2mm raised exhaust port, sb50 reeds, 34mph average.
circusracer
I still run the hose from the intake to the petcock, just to make sure I dont run into a lean issue. It has no effect on the flow of petrol.
circusracer
circusracer
You should cap the vacuum port on the intake mani.
cf_z
Post by cf_z »
i was thinking about drilling it just to see if that was the problem, but i wasnt sure if itd work :)
thanks man, ima do that this weekend and see what happens !!
94 Elite SR.
=fast
circusracer
Kenny_McCormic wrote:You should cap the vacuum port on the intake mani.
Noted, I will take care of that tomorrow and let you know the results. Thanks Kenny
Before you mutilate any innocent petcocks, be aware that these fittings can be purchased in the plumbing department of any Home Depot near you:
Note the item numbers. Assemble with Teflon tape. The barb is too big for fuel line, but a lot of AutoParts fuel filters have a small fuel fitting telescoping into a larger one as sort of shown in pic. Big hose in, small hose out, problem solved. The whole mess was under $20., including filter.
Wheelman-111 wrote: ...but a lot of AutoParts fuel filters have a small fuel fitting telescoping into a larger one as sort of shown in pic. Big hose in, small hose out, problem solved. The whole mess was under $20., including filter.
I've had problems with that exact filter not flowing enough fuel to the carb. Is that filter working for you?
Admin, Hondaspree.net
The problem with running no valve at all is if the float/needle/seat decides to fail, your house/shed/garage or whatever outbuilding have you may rapidly disintegrate into toothpicks.
circusracer
Got a vacuum nipple cap set at autozone for $2.00, capped of the manifold nipple and so far rode three miles today and everything was great.
