rear wheel?!?!?!
rear wheel?!?!?!
I cant get it off. Is there a special trick? HELP
- CharlotteSpreeRider
I've had occasion to use the rear brake to assist with holding the wheel still. I turn the nut on the back end of the cable until I can barely squeeze the brake handle. Then I squeeze the rear brake handle real hard, and use the brake locking thing to hold it there. Then I turn the nut off the rear axle with a cheater bar.
-aseigler
-aseigler
is it spinning when you try?
If your brake can't old the rear wheel still enough to remove it then you will probably need a impact wrench. I had an electric impact wrench so it was pretty easy.
You can try to get someone to sit on it while you loosen it. If you have something with a really long handle that you can put around the socket and really go fast at it then that might work.
If you don't want to spend the big bucks on a impact wrench then you can buy one of these puppies.
http://www.sears.com/shc/s/p_10153_1260 ... ord=impact
You put it on the bolt and then hammer the back of it and it will get it going for you.
Sticky Nuts
Ah, the stuck Axle Nut. What tool are you using? I recommend six months of intensive weight training, or you can hire a mountain gorilla or you can provide Wheelman with airfare to your location. (I have the strength of 111 ordinary Wheelmen...)
Nuts can be tough to crack, but through The Miracle of Leverage, almost all can be removed. (WARNING: Do NOT search the forum for rumored Wheelman Misadventures with a front axle removal.)
A box-end wrench is the preferred tool. If it won't budge, try a longer one. A cheater bar can be added to increase your applied torque - just a length of pipe slipped over the wrench as an extra-long handle.
Still too stubborn? It's surprising how a little heat applied to a nut can help it let go of its comfortable, familiar situation and grow and become a more fulfilled, self-actualized nut. Unfortunately the NyLoc self-locking material will be rendered useless with a flame torch. You could consider a heat or paint-remover gun, but be prepared to have to replace the nut. Wheels falling off can hurt.
AustinS wrote:is it spinning when you try?
luckily I do dispatch for a crane company so weve got impact wrenches and much more thanks
superspree09
Re: rear wheel?!?!?!
I feel your apin. I just bought my first spree. It is in pretty ugly shape. I tore down 90% of the bike in about two hours, cleaning as I went. That was the other night. I have spent more time today just trying to get the darn rear axle nut. First I tried to get it with a hammer on the end of a long box end. Then I went to the cheater. Both started the stripping process. I tried the WD-40, heat, and a cheater bar...
...NOTHING, unless you count totally stripping it out. I am now at a pipe wrench and sledge hammer!!! SWEET
- SpyderMike
the first time i tried to get my rear wheel off my sb50 i had the rear break locked, i was holding the wheel, and my wife was sitting on the bike....wheel still spun/lifted bike off ground
so i took the tranny cover off and put a wrench on the clutch nut...the gearing helped me hold it still while i d*** near dislocated my shoulder breaking it loose
never had that problem again (knocks on wood)
i just take a pipe and put it in the wheel trough the mag and put a breaker bar on it and SQUEEEEEEEEEEK it is free. then a little cleaning and it never takes a ton of pressure next time
hahahh
hahahh
any safety issues with putting these back on? If it takes that much to get it off, what should you use to put it back on? I'm assuming your standard ratchet isn't gonna cut it
1984 Honda Aero 50
1986 Honda Spree
1986 Honda Spree
- bradthreee
Usually takes a heavy duty screwdriver proped between the spokes and leverage from the case. Large ratchet then one good blow with the rubber mallet usually does the trick. O I forgot to mention use whatever lube you have around (KY, WD, Liquid Wrench) and let soak for about 30 min. After you get the nut off make sure you wiggle the rim side to side a bit then pull as you wiggle.
Or an impact would work too
dreamer1uk
- BMX
Hi,
I just used a breaker bar and a 6 point quality socket. I just sat in the Spree and broke the rear axle nut loose.
When you are ready to put the rear wheel back on, the proper torque spec for the axle nut is 47 to 58 ft lbs. Again, i just sat on the Spree to do this.
Hope this helps somewhat
Cheapo 12V impact wrench from Harbor Freight ($19.99 when on sale) does the job quite well for me and saves me having to drag out the compressor!
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
