SA50P (Restricted guys) Oil pump Q
- burnt_toast
Workin on my '98 SA50P today I realized I did not have the split throttle cable going to the oil pump like on my SR50's
I went ahead and rigged it wide open, but wanted to confirm that was the best thing to do, thoughts?
Mods at the moment are exhaust and variator, more coming soon
projects galore
- bradthreee
Factory Setu-P
BT has no pump cable:
How was it set up from the Factory?
- burnt_toast
Re: Factory Setu-P
yup no cable, therefore oil pump is on lowest possible setting at all times.Wheelman-111 wrote:Greetings:
I went ahead and tied it fully open since I recall Dac and others doing the same.
I was just curious about the main jet this morning, exactly what I needed to know as far as that goes thanks veedub!
projects galore
- burnt_toast
- burnt_toast
- bradthreee
if you took out the welded washer out in the exhaust,the 78 main is to small still.you have to bump it to a 85 or 88 jet.yes tie open the injector.
- burnt_toast
85 or 88 main at 50cc??bakaracer wrote:if you took out the welded washer out in the exhaust,the 78 main is to small still.you have to bump it to a 85 or 88 jet.yes tie open the injector.
my only current mods are YMS exhaust and OKO pulley with 7.5g net
78main seems fine, my jog had 76main, stock bore, stock carb & box and with a tec RS pipe worked good.
maybe you have to bump yours up because of elevation? I'm very close to sea level here
and brad thanks for the offer but I have a spare split cable, but will be going to fully adjustable for a carb upgrade in the future anyway so wiring pump open seems good to me
projects galore
- scooterwerx
im running a 90 in my elite e with nb50 engine, it has the leo vince sp3 and a uni filter, it still looks a little lean too! the added rpms really get the fuel going, i guess. i found it necessary to increase the jet to an 85 just from the filter, and the pipe just made it scream, more rpms and i could tell it pulled way harder off the bottom. i dont know if derestricting a stock pipe would yield the same results, but an 85 sounds like a good starting point, im at 1300ft of elevation btw.....
- burnt_toast
