Lamb
Posts: 44 Joined: Sat Dec 27, 2008 9:59 pm
Post
by Lamb » Thu May 07, 2009 7:36 pm
what could i use instead? my carb is leaking gas ;P
toboggan
Posts: 744 Joined: Sat Mar 21, 2009 2:55 pm
Post
by toboggan » Thu May 07, 2009 7:41 pm
New gaskets?
Lamb
Post
by Lamb » Thu May 07, 2009 7:43 pm
don't you come at me with your logic, i need cheap , d*** it
bradthreee
Posts: 1922 Joined: Tue Sep 12, 2006 4:20 pm
Post
by bradthreee » Thu May 07, 2009 7:50 pm
Gaskets are cheap
Lamb
Post
by Lamb » Thu May 07, 2009 7:53 pm
$9 for the whole carb gasket set on the OEM sites, + $8 shipping for a total of $17, which is ridiculous
i'd like it to be closer to the range of $0
i was half-contemplating laying down a few strips of thread seal tape >.>
i might go and cut a gasket out of a cereal box, hmm
chevyguyjay
Posts: 1167 Joined: Sat Feb 03, 2007 5:09 pm
Post
by chevyguyjay » Thu May 07, 2009 8:05 pm
geeeeze send me 3 bucks, and ill mail one to u.
~2004 Geely Fashion~
bradthreee
Post
by bradthreee » Thu May 07, 2009 8:11 pm
mmm maybe try bubble gum
Lamb
Post
by Lamb » Thu May 07, 2009 8:24 pm
you know, i'll probably end up buying one from someone
but before that i'm going to make an * out of myself and use a Special K custom-made gasket
bradthreee
Post
by bradthreee » Thu May 07, 2009 8:36 pm
Be careful with stuff like that it might get stuck in your engine and cause a more expensive problem in the long run
Posts: 10683 Joined: Wed Oct 22, 2008 5:09 pm
Post
by Wheelman-111 » Thu May 07, 2009 8:38 pm
You could use the rim of a condom, unless you's white. I would avoid the NaturaLamb, however.
Seriously, Honda-san stocks these or can get them in 2 days. They are round-section O-ring style, so you'll need to be precise with that X-Acto. I would be impressed if you pull it off.
Lamb
Post
by Lamb » Thu May 07, 2009 8:48 pm
here it is:
despite the obvious stupidity in using this, there's a 99% chance that i will end up doing so
Lamb
Post
by Lamb » Thu May 07, 2009 9:13 pm
well crap, i figured i didn't have a gasket because there was a rim of gas between the carb and the float, but upon opening it there is a rubber something-or-other attached in the lining of the carb
* is going on
im considering just wedging the cereal cutout between the float and carb anyway
Lamb
Post
by Lamb » Thu May 07, 2009 9:53 pm
so i went and installed the cardboard piece, and i think the gas leaking problem is even worse now
i think i'll go ahead and remove it, but i don't know where to go from there
chevyguyjay
Post
by chevyguyjay » Thu May 07, 2009 9:53 pm
Lamb
Post
by Lamb » Thu May 07, 2009 9:55 pm
im not seeing how i'd get the circle rim of a condom to fit over the weird shape of the carb :/
i would like to know why my spree is being a little b**** and crying tears of gas constantly though
