'97 Elite (SA50) Inner Tube Questions
Chisholm
Post by Chisholm »
So, I had a tube blow out a few weeks ago at 35 mph :(
I bought a replacement tube from the local shop. The old one was 2.5x10, and that's what I asked for, but the guy brought back a 2.75/3.0x10 and said it would fit.
So, I installed the tube, but now the tire is out of round. I've checked it, deflated it and reinflated a few times, but the problem perisists. I also couldn't get the valve stem to seat properly. It's an angled one, and the base won't go flush through the rim; it might if I really beat on it. It's also not a screw in like the old one.
My question is whether my problem is user error or the wrong part. What do you guys think?
-BTW, the new tube is made in India by Prima.
burnt_toast
Post by burnt_toast »
The inner tube size you installed is correct, since stock tire is 3.00-10
but if valve stem isn't fully seated then that could be throwing it off. try to find a proper straight stemmed tube if possible
projects galore :nerd:
scooterwerx
Post by scooterwerx »
if the stem doesnt seat it will definitely not allow the tire to seat correctly. out of balance tires are a scary thing, especially when they are so small!
Chisholm
Re: '97 Elite (SA50) Inner Tube Questions
Post by Chisholm »
I've narrowed it down to the tire not seating.
How much air should I use to seat it? I've been pumping it to 40 psi, a la car tire, but it won't seat. Tried lubing it too.
'86 Spree - Stock
'97 Elite SR - Gears and Variator
'99 Jog - Stock
I'd remove the tire completely and check the bead for kinks and the carcass for any obvious flaws. Could it be that the tube went south because the tire's delaminating. There's a number stamped on the sidewall that indicates the week/year the tire was cooked. If it ends in 04 or less, just get a new one, unless your saftey's not worth $25. Most 5-year-old tires hold together just fine, but some don't. :(
wiguy05
Re:
Post by wiguy05 »
scooterwerx wrote:out of balance tires are a scary thing, especially when they are so small!
I had a Spree tire blow out on me last year. Sounded like a gunshot at ~25mph. Almost dumped the bike too.
I will admit, the tire was pretty bad, too many one wheel peels with the new scoot :shock:
2006 Sachs Madass
- FTP 140cc Kit
2006 Xkeleton Trickster
- Lifan 90cc auto
Chisholm
Post by Chisholm »
You've got a point Wheelman...
I examined it and it seemed okay when off the rim.
But you guys didn't answer my question, how much pressure does it usually take to seat the beads?
'86 Spree - Stock
'99 Jog - Stock
A tube-type tire on a tube-type rim will not need to "seat" violently like a car tire. I hand-mounted my Pirelli and a new tube, adding pressure with a foot pump. The tire found its way gradually down to the rim flange and was correctly centered without any special effort on my part. Of course it was a new tire...
Chisholm
Post by Chisholm »
Sounds like I won't go with my plan of finding a cage to put it in and taking it to 60ish.
Thanks Wheeldude.
'86 Spree - Stock
'99 Jog - Stock
