Do you grease your vari?
Posted: Tue May 12, 2009 4:34 pm
by coolbeans
Just got a used Keli vari from Wheelman and am working on putting it on...the old one was packed with grease and the manual calls for new grease on reassembly. In another post, Kenny mentioned that it was ok to run dry and didn't result in extra wear. I'm not doubting you, Kenny, but I'd like to know if everyone else runs their varis and rollers without grease.
Posted: Tue May 12, 2009 4:43 pm
by evilone
Very very light coating on rollers only.
Posted: Tue May 12, 2009 4:47 pm
by coolbeans
Thanks for the quick reply!
Greasy Rollers
Posted: Tue May 12, 2009 4:52 pm
I stopped using grease of any kind, except some Dry Lube on the ramp guides. I also recommend rounding off the sharp edges on the ramp plate, as they seem to "shave" plastic off the rollers. Why isn't this Factory? Roller-makers have to eat too.
Posted: Tue May 12, 2009 5:01 pm
by coolbeans
Hey Guy,
Thanks...
Did your moveable face seal fit on the Keli? The Keli is a bit larger(DUh, that's why it's better!) and the seal won't fit around it. Did you run it without the seal and the O ring?
Chester
Posted: Tue May 12, 2009 5:14 pm
by coolbeans
Posted: Fri May 22, 2009 12:25 am
by Elite1998
evilone wrote:Very very light coating on rollers only.
I agree
Posted: Fri May 22, 2009 2:22 am
by scooterwerx
i used to give a quick spray of moly grease, but now i go dry, in theory the grease makes the rollers slide, more friction makes them roll. havent had a problem in almost 500 miles with the nb elite e. less mess too!
Posted: Fri May 22, 2009 3:38 am
by Arnadanoob
No grease. All of my bikes run Keli variators and Daytona roller weights and I've never had the need to grease anything so far. While there are some cases where I'd have to make a few corrections to variator imperfections but that's it.
If you must use a lubricant, the only ones I'd recommend is the dry graphite type used for locks.
Posted: Fri May 22, 2009 9:00 am
by burnt_toast
yup, I'm same with Arnada
ran loads of performance variators past 5yrs and never used grease. I've tried it but saw no benefit really, just messier disassembly
can try graphite dry lube though if you're adamant about it
