The scoot finally started with a little love when I first got it (about 5 months ago) but it just stopped one day and wouldn't start again. The engine would turn over but it wouldn't start. I had my uncle take a look at it (he's really into go-carts and stuff) and he got it to start again by messing with the spark plug wire. It ran for about 3 and a half miles better than it's run before, even getting up to a little over 30 miles an hour, before it did the same thing. Now it won't start at all.
Do you guys think the sparkplug is the problem again? And if it is, is this a symptom of another problem? How can I get that sucker to stay in place if it turns out it's loose again?
Thanks.
Sparkplug issues? Engine turns over but won't start...
- tazland001
well first you want to test for spark. Unscrew the spark plug cap and get a pair of rubber handle needle noose pliers. Make sure the bike is the on position. Touch the tip of the spark plug wire against a ground(head, bolt,ect) and then hit the electric start. If you see and hear the spark snapping on the ground you know your electrical is most likely good.
Now it might be compression. That sounds more like the problem. See if a honda scooter sits for a while the combustion chamber will slowly start to fill with oil. Gravity pulls oil into the chamber throught the oil pump. This will cause a scooter to sometimes start and run for a bit after they have sat with weak compression. What model scooter do you have?
