My Spree broke already!
- MaskedJellybean
I had my Spree running fine for about 8 hours. (not continuously of course) Then as I was driving it on a dark street, I ran over a large pothole. Immediately afterward, I started to lose speed and power, finally the engine and lights just completely shut off and I rolled to a stop. I later got it to start up again, but now it can't seem to get above 10 MPH. I cleaned out the carb (following the directions on this site) and checked the air filter, but it's clean. I played around with the air intake and throttle adjustments on the carb, but that didn't make a difference, so I put them back where they were. Since I didn't know how to do anything further, I took it to a repair shop (I know I should have posted before I took it in) and I'm still waiting for them to call me. I really hope it's not something serious, but I suppose it is. Does anyone have any ideas of what it could be?
my spree died after riding off a curb and it was my rings. which also destroyed my piston. i dont think that is what is wrong with yours if it starts again tho. when that happened to me i had 5psi of compression.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
- MaskedJellybean
- MaskedJellybean
- Farfignugin
happened to me several times. I checked the most obvious first and i was right. The spark plug wire was not seated all the way on the plug.
You said this happened right after you rolled over a pot hole. It could have jarred the plug wire loose. Always check the simplest answer to the problem first before you take it to a money hungry mechanic or scoot shop. A shop not far from me charges 75.00 to check out a carb.
I am definitely in the wrong business.
- MaskedJellybean
- MaskedJellybean
Turns out, when I hit the pothole, some dirt went up into my muffler. They had to blast it with a blow torch to get it out. So my Spree worked fine for an hour, and now I have a completely new problem! Yes!
As I was driving, I just suddenly lost all power. Now I can't start it at all. Not even with the kick start, it won't go down. When I do the electric start, all it does is make a clicking noise and the back lights go out for a split second. Could it be the spark plug? Because isn't that part of the ignition process?
All I can say is I'm getting pretty * at my spree. It left me without any power in the middle of a ghetto, and I'm a skinny white guy. Does anyone else seem to have some sort of trouble every time they drive somewhere, or is it just me?
- MaskedJellybean
As far as your spree just dying as you drove it could be several things.
1 Thats what mine did when spark plug wire jarred loose.
2 Could be your carb is plugged with a little particle of dirt or debris.
3 Could possibly be a bad or dirty plug.
You also say you can"t kickstart it and makes a funny sound with electric start.
1 Make sure your battery is charged or hook up charger to it while trying to crank it over with electric start.
2 If your kickstart seems jammed then you will have to take kickstart cover off and see what the problem is.
3you may have a bad starter or starter pinion gear.
4 Check to make sure there are no disconnected wires.
5 If you haven't downloaded th spree shop manual i would do so now.
It will definitely come in handy if you want to work on it yourself.
