Page 1 of 5
Super Duper Aero Scooter
Posted: Wed May 27, 2009 8:26 am
by GIJoeBob
I am starting a new scooter project.
I have a 1986 Aero 50 that is pretty much complete.
I plan on removing all the panels and going for a rat/chopped sort of look and I want/need ideas to maximize the performance of the bike.
I have been to the VT Cycles and plan on getting several of their items.
http://www.vtcycles.com/vtc_plugins/zog ... .php?cat=4
What are some other options I should consider?
Posted: Wed May 27, 2009 10:55 am
by scooterwerx
soooo, will you be selling the rest of it? the question of how much performance is answered by the question, how much money do i want to dump into this thing!
Posted: Wed May 27, 2009 11:46 am
by GIJoeBob
scooterwerx wrote:soooo, will you be selling the rest of it? the question of how much performance is answered by the question, how much money do i want to dump into this thing!
Whatever I end up not using I will be selling. As far as how much money, that will be a judgment call weighing cost/benefit.
Posted: Wed May 27, 2009 1:17 pm
by bradthreee
Talk to Wheel-man, he is the Aero sensei
Re: Super Duper Aero Scooter
Posted: Wed May 27, 2009 10:20 pm
by turtle13
i would say a big bore kit, and a variator are in quick order. other than that... not sure. maybe design an exhaust with an expansion chamber?
Posted: Wed May 27, 2009 10:33 pm
by scooterwerx
ruckus variator and leo vince sp3 will get 45mph easy, a 3.0-10 will give a few more.
Posted: Fri May 29, 2009 4:15 pm
by GIJoeBob
I took a picture of the naked scooter -
crappily removed the background -
and then made the frame mods I am thinking of just to get an idea of the look -
raked the fork out a bit, stretched the frame and stretched the motor mount.
Posted: Sat May 30, 2009 11:59 pm
by turtle13
all i have to say is if you make a longer motor mount, you need to document heavily the process, as well as share plans. i was thinking about doing this over the winter when i plan on putting a big bore kit on the scoot. if new mounts were fabricated you could also off-set the mounts to the side a little accommodate for a larger rear tire.
Posted: Sun May 31, 2009 12:32 am
by scooterwerx
not too much room for larger tires, i mocked up a ruckus wheel, 10x3.0, and theres no way. it has less than a 1/16" clearance on the case side, mine is barely tweaked and it rubbed. with the LV SP3, no way, stock muff maybe.
Posted: Sun May 31, 2009 12:38 am
Nice photo mock up work. I've been trying to visualize what you were going to do. If a genuine Aero frame tube piece would ease the frame lengthening, PM me, will make an attractive deal.. Great project - can't wait to see your progress.
Posted: Sun May 31, 2009 12:43 am
by 808BMW
turtle13 wrote:all i have to say is if you make a longer motor mount, you need to document heavily the process, as well as share plans. i was thinking about doing this over the winter when i plan on putting a big bore kit on the scoot. if new mounts were fabricated you could also off-set the mounts to the side a little accommodate for a larger rear tire.
Cut it in half, add material in the middle, make sure it's welded straight. Get longer cables and relocate your shock.
scooterwerx wrote:not too much room for larger tires, i mocked up a ruckus wheel, 10x3.0, and theres no way. it has less than a 1/16" clearance on the case side, mine is barely tweaked and it rubbed. with the LV SP3, no way, stock muff maybe.
A spacer on the wheel hub nets more case clearance, modding the exhaust isn't so easy. You can space it out easily, but it won't connect to your bore anymore :P
Posted: Sun May 31, 2009 1:18 am
by turtle13
yeah, at that point there is almost no point in stock exhaust. if your gonna customize everything that far, you gotta do the exhaust too. I think the hard part would be finding a wheel that fits with the right back spacing that works.
Posted: Sun May 31, 2009 2:53 am
by scooterwerx
the stock ruckus wheel is stamped steel, when the front wheel on my brothers ruck got twisted, i put it in the press and straightened it, im sure the rear could be offset to clear the case.
Posted: Mon Jun 01, 2009 3:41 pm
by GIJoeBob
I do plan on doing the big bore as well. I'll take some photos of the mount ASAP and post them here to get some opinions.
Posted: Mon Jun 01, 2009 11:23 pm
No doubt a stamped wheel could be offset with Tools of Mass Destruction, but be careful there, pard. When the front and rear tires' contact patches lie on different lines, handling can get... uh... interesting. Harley dudes to this all the time to mount earth mover tires astern, then invariably regret it.
