1986 Spree Spark Plug
Posted: Sun May 31, 2009 11:28 pm
by Lamb
is the BPR6HSA common enough to be at autozone, and if not, is the BPR6HS compatible with my '86 spree?
danke.
Re: 1986 Spree Spark Plug
Posted: Mon Jun 01, 2009 1:11 am
by scooterwerx
the "a" designates special design, i dont know what exactly it specifies, but it looks like the tip of the electrode is slightly shorter, hasnt made a bit of difference in anything ive run them in...they have those at the zone...
Posted: Mon Jun 01, 2009 7:59 am
by toboggan
Yeah, i'd say if you can't find the 'A' model, just go with the other one.
oh and... Danke Schon.
Posted: Mon Jun 01, 2009 3:45 pm
by dreamer1uk
Hi,
There is a link around here with alternatives to NGK plugs as well as the 3 NGK's you should go with depending on how long of a trip you take your Spree on
Posted: Mon Jun 01, 2009 5:47 pm
by Lamb
i went to autozone, and the clerk lady was retarded and didn't know how to operate the computer system
so i went to advance, and the guy said he didn't have any of the BPR6HS or autolite 284s in stock, so he gave me an autolite 21something that works. i noticed a small performance gain, but my spree still randomly bogs down (loses 2-4 mph, stays at lower speed, then 'clicks' and goes back up to full) regardless of what i'm driving on :/. would a carbon cleaning of exhaust and cylinder possibly remedy this, and if so, is it required that i replace the gaskets- and if so, how much will that run me?
thanks again.
Posted: Tue Jun 02, 2009 1:12 am
by scooterwerx
eek, its scary running plugs of unknown heat range, was the plug hotter or colder than the stock equivalent one? the loss of power sounds more like a carburetion issue, but i would definitely find out how the autolite "21-sompin or udda" compares to the heat range of the stock plug...
Posted: Tue Jun 02, 2009 8:01 am
by toboggan
So that just confused me a lil. lol.
So what would the best spark plug be if you ride 10 miles WOT?
What about for just driving around the city, with constant stop and goes?
Posted: Tue Jun 02, 2009 9:15 am
by Lamb
well, the plug he gave me (autolite 4123, actually looked at the box) was the one that showed up in the system for NQ50- Spree, so i can't imagine it'd be wrong for it. the mileage is a little bit higher though, around 3500 miles, so that's why i was considering a cylinder/exhaust cleaning
Posted: Tue Jun 02, 2009 5:20 pm
by Kenny_McCormic
BPR4HS for below freezing.
BPR6HS for most stuff(this is what they come with stock)
BPR8HS if top speed will be maintained for more than a mile.
For example, I only ride in the summer and "town" is a few miles away, therefore I run the 8.
If I lived in the city I would run a 6, if I was * crazy and ran it in the winter, I would install a 4. Probably wouldn't hurt to drop the R, you don't have a radio and therefore don't need the resistor to dampen RFI/weaken the spark.
