I found a used windscreen on Cragslist for $15.00 bucks ... Thought it would look funny on my Gyro 1 problem finding mounts they range from $15.00 to $ 45.00 I got a $15.00 set at a Chineese moped shop .
66SIX wrote:I found a used windscreen on Cragslist for $15.00 bucks ... Thought it would look funny on my Gyro 1 problem finding mounts they range from $15.00 to $ 45.00 I got a $15.00 set at a Chineese moped shop .
I have an accessory sheet from back in the 1980s for the Aero line up and there were windscreens for all the models. So like Kenny said, I would suspect there were windscreens for all models available.
'84 Aero 80 X 3 '85 Aero 80 '84 Aero 125 X 2
'84 Aero 125 '84 Aero 125 X 2 '85 Aero 50
Thanks Bear - I've been in agreement with Kenny all along, just slow at tracking down and posting photos. Photo updates below. BTW would you like to scan that accessory sheet? Bet folks would like to see it
you can make your own like i just did, template,lexan an oven and a pipe then tint it with lense tint, use rubber grommets and stay away from mango trees, mine was done for a gtr-50= thanx summo
maddog wrote:you can make your own like i just did, template,lexan an oven and a pipe then tint it with lense tint, use rubber grommets and stay away from mango trees, mine was done for a gtr-50= thanx summo
Making your own is
I don't know how maddog did it, but the bicycle guys have made blown fairings in their garage. A windscreen does not need as much shape, but has features to wrap around the handgrips etc. to keep the icy/wet blasts off the rider. It would also be thicker than a bicycle sized component, so process adjustments are needed. Anyhow, a template of the desired profile, and moderation on how much 'blow' could be fun experimentation for a scooter windscreen. http://www.wisil.recumbents.com/wisil/b ... ubbles.htm
Here's another piece to the puzzle. This is from Honda Canada from 1984, so it's not totally applicable to the USA market but usually (always?) any accessories that were sold in Canada were also sold in the USA. It seems that even more accessories were available in the USA since the windscreen is not listed for the Spree here:
