this year it runs different
Hello everyone,
Had the 86 spree running good last summer, not so good this summer. This year I cant get it to match its 27 mph speed of last summer it peaks at 25 mph. The exhaust color seems normal after its warmed up. I've also adjusted the air screw. No luck. Its been bogging down when I get it up to top speed. Last summer I pulled apart the carb cleaned it thoroughly, bought a new air cleaner and air filter, and replaced the choke. The gas was drained and it was stored in a warm basement for the winter.
I'm stumped. Could the carb need to be cleaned again? Any one have any ideas?
thanks,
SWF
thanks,
SWF
- burnt_toast
Hey SWF, welcome back.
I'm guessing that your carb needs recleaned. Are you running fresh gas, or it is a year old? Bogging is typical of running too lean.
Admin, Hondaspree.net
By the way, to answer a really old question you'd asked; the Aero 80 rear shock/spring is rumoured to bolt up to the Spree. This will keep it from bottoming out for more agressive riders. I see these on Ebay every once in awhile.
Ok I did the carb clean. It was better for a while then it slowly whent back to the same. 25 top speed and bogging. I noticed a good amount of oil in the carb plus on the spark plug. So I'm guessing this is the problem since it seemed to have run good for a while after I flushed out the carb.
Is their a way to adjust the amount of oil that mixes with the gas?
Is this the kind of problem that means my little spree is doomed?
Hey noiseguy thanks for the tip on the shock. If I get this thing running good again I'll look into it.
sf
sf
I wonder if the bottom end hasn't filled up with oil over the storage, due to a slow leak in the oil pump. Thus the engine is fouling plugs, and will until it burns off.
Either that or your rusty tank is filling the carb bowl with crud and plugging the idle jet.
BTW, you are using injector oil, and not a premix oil, correct?
they sell something to put in that tank and it seals it and covers the rust.noiseguy wrote:I wonder if the bottom end hasn't filled up with oil over the storage, due to a slow leak in the oil pump. Thus the engine is fouling plugs, and will until it burns off.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
Yes, Kreem or POR15 Tank Kit. Problem is that then flakes of the sealer come off and plug your idle jet and filter, instead of the rust. I had good luck with acid cleaning mine, and it's cheap ($5 and 2 hours of shake and wait.)
