Any words of advice on how to set up a work space? I'd also like to see other people's pics. One thing I don't like is that the chair is a little low to work at the bench, and a little high to work on the scooters. My back hurts a little.
Unfortunately no I don't. I never bit the bullet and bought one. Too expensive. I was doing mostly single color by hand, eyeballin' every print, lol. I have a box with some used Speedball inks, some squeegees and two huge, really nice screens that only got used like 3 times. Oh and also a hand built exposure unit with like 8 bulbs (one set UV and one set White Blacklights, which sounds confusingturtle13 wrote:don't have a 4 color press you wanna get rid of?
Build a table to set your bikes on top. You'll be able to get under it a bit easier, and you can sit in your chair and work perfectly.adark248 wrote: Any words of advice on how to set up a work space? I'd also like to see other people's pics. One thing I don't like is that the chair is a little low to work at the bench, and a little high to work on the scooters. My back hurts a little.
this is going to be one of the first things i am going to do. Well i say that now, but then im sure once we move in the "honey do" list will start piling up fast...Build a table to set your bikes on top. You'll be able to get under it a bit easier, and you can sit in your chair and work perfectly.
man, i wish i had your craigslist... here in KC they go for consistently 300 and up.noiseguy wrote:Get a motorcycle lift used (see them for $60 all the time) or build a small 1'-2' table to support the bike. Get a roll-around seat from Sears and a 24" countertop chair to replace the substandard 18" table chair. Otherwise looks good!
How do ya get ahold of one?noiseguy wrote:A milkcrate works well as a center stand. Has to be the real thing, though, not the thin plastic knockoffs that Target sells for putting files and books in.
