hard to start, idles for a bit then dies....
the other day i finished putting everything back together and i started it up and it ran fine but when i went to put the body pieces back on i though that i would adjust the carb a little so started it up again and it idled but when i gave it any throotle it wants to die... i took of the carb made sure it was all clean but it back on and it was even harder to start and dies within a couple seconds.....it alos revs up and down and i notice some sparks in the exhaust.. . this thing has given me soo much trouble i dont kno wut to do anymore......
Don't run without the bystarter; you risk leaning the engine out and ruining it.
If the float doesn't float in gas ie fills up with gas, that can be a problem.
Dirty spree carbs are the problem 90% of the time.
