Page 9 of 21
Re: Sprelite The Begining Of My Epic Build
Posted: Tue May 10, 2011 5:33 pm
by SpreeMadness520
It has to be the variator or something, I will take it off and look soon. Hopefully it is easily fixed because I want to ride...
Posted: Tue May 10, 2011 5:38 pm
by Trafficjamz
SpreeMadness520 wrote:It has to be the variator or something, I will take it off and look soon. Hopefully it is easily fixed because I want to ride...
Your rear pulley was badly bent. we replaced it but the belt could have become worn unevenly.
Try a new belt maybe?
Posted: Tue May 10, 2011 5:42 pm
by SpreeMadness520
Does the spree belt fit? But I really dont think its the belt...Its having the same symptoms it had before you fixed it....
Posted: Tue May 10, 2011 5:46 pm
by Trafficjamz
SpreeMadness520 wrote:Does the spree belt fit? But I really dont think its the belt...Its having the same symptoms it had before you fixed it....
no the spree belt is too small.
Make sure the air box is on tight.
Posted: Tue May 10, 2011 5:47 pm
by SpreeMadness520
Ok I will check that, It revvs and goes no where
Posted: Tue May 10, 2011 5:49 pm
by Trafficjamz
SpreeMadness520 wrote:Ok I will check that, It revvs and goes no where
Like the belt is slipping? Or no power to move?
Posted: Tue May 10, 2011 5:54 pm
by SpreeMadness520
No power to move, Its getting even weirder now...
Posted: Tue May 10, 2011 5:56 pm
by SpreeMadness520
Its probably the flywheel key or something that was wrong last time
Posted: Tue May 10, 2011 5:59 pm
by MopedMark
Did the front drive gear come loose and come off the splines?
Posted: Tue May 10, 2011 6:01 pm
by SpreeMadness520
Its the flywheel....****. Its a makes a friction sound when I turn the wheel now. The noise was on the variator side but now its on the other side.
Posted: Tue May 10, 2011 6:11 pm
by SpreeMadness520
This is really starting to agitate me, Im spending way to much money on a project that should be relatively "bolt on"
Posted: Tue May 10, 2011 6:55 pm
by SpreeMadness520
I think im running out of things that can go wrong, Ill probably need a new flywheel this time
Posted: Tue May 10, 2011 9:02 pm
by evilone
SpreeMadness520 wrote:Its a makes a friction sound when I turn the wheel now.
When you turn the wheel, like rear wheel?
Posted: Tue May 10, 2011 9:04 pm
by SpreeMadness520
No the drive face gear, Idk what happended TrafficJamz probably has a better idea than I do. But it sounds like * when I touch the throttle
Posted: Tue May 10, 2011 9:54 pm
by SpreeMadness520
After a quick teardown I figured out the flywheel was loose, I took the fan off and tightened the flywheel nut. Running good but not quite right, Still not sure about the flywheel key...
