Page 6 of 12
Re: Need a quick help For my friends Honda Elite .
Posted: Wed Apr 11, 2012 11:58 pm
by Duke250
Oh man you did a nice job !! That is how I want my plastic to look like just like yours. I am going to try the same thing you used hopefully I will come with a good result.
Re: tip on painting
Posted: Sat Apr 14, 2012 9:31 pm
by Duke250
how long to I have to wait before I apply the dupli color primer filler on the repair area ? Also should I apply the primer filler on all the panel or just the repair area?
I had used the fiberglass repair and Bondo for my filler.
Re: Honda elite and spree body rebuild
Posted: Sun Apr 15, 2012 7:38 pm
by Duke250
couple more things to go before I can paint .
Posted: Thu Apr 19, 2012 12:34 am
by Duke250
dun rite wrote:glad you got it going. for speedo you need to check the cable, possible stripped gears on the wheel end. hard to say. Hope you have good luck with that carb.
Yep I found why th speedometer is not working my wire insinde the cable is broke
Posted: Thu Apr 19, 2012 12:50 am
by Duke250
Hey guys what is the Difference between honda elite 1998 sa50p and 1988 sa50 ?
Also what is the best oil to used on it ? Do I need to buy 2 steppe engine oils ? Thanks
Some updates on my spree .
Posted: Thu Apr 19, 2012 3:59 pm
by Duke250
Yesterday I got most of my spree panels paint with Rustorleum Enamel paint.Did a pretty good job. I am waiting to apply the Clear coat may be Saturday . Want to give it time to dry.After clear coat . I am going to let it sit before I can sand and polish .
I steel can't can't decide on the color for My 1998 Sa50p Honda elite.
Posted: Thu Apr 19, 2012 10:30 pm
by dun rite
looking good.
Posted: Fri Apr 20, 2012 7:48 pm
by Duke250
Thanks It is not done yet haven't apply the clear coat .
Posted: Sun Apr 22, 2012 11:15 pm
by Duke250
Check this out Bonesv I used the kind or paint that you required to me on my elite . Man those parts look so beautiful.
Posted: Sun Apr 22, 2012 11:30 pm
by donut
Duke250 wrote:Check this out Bonesv I used the kind or paint that you required to me on my elite . Man those parts look so beautiful.
like the satin black!
what exactly did you do and use please?
(I will be painting my aero in rat rod fashion and want a satin or flat black color)
Posted: Sun Apr 22, 2012 11:34 pm
by bonesv
Man, those look great! Yea, there's alot to be said for that paint. It's the hot ticket!
You did a real nice job.
Keep posting the results for us on the rest of it.
Posted: Sun Apr 22, 2012 11:46 pm
by Duke250
i used the duplicolor trim paint to prime it and then the bumper coat for my finish. Also they are flat black color no gloss in them . You can get those paint at an Auto parts store. Just apply those paints like the instruction say and it will come out nice with no runs.
forget about rustorleum spray paint.
Posted: Wed Apr 25, 2012 9:00 pm
by Duke250
have some updates on my Elite. I had all my plastic painted that satin black and now today I got most of my panels done too. Now I've used Duplicolor on my Honda elite and Rustorleum on Spree. I did that because i want to compare both together. Now I found out that Rustorleum if you take your time it can get the job done but take a long time to dry. By the time it is taking to dry it easy for anything to damage your work. Now with Duplicolor that thing dry so quick and buy the time something will go wrong with it . Duplicolor will be on its way to dry . Now with the can I like the way the duplicolor paint shoot the paint . It is easy to apply then rustorleum paint . Those are what my panels look like . I haven't apply the clear coat yet.
Posted: Wed Apr 25, 2012 9:06 pm
by Duke250
now the transparent coat.
all most satisfied !!!!!
Posted: Wed May 02, 2012 9:16 pm
by Duke250
one down still have three to go . I haven't applied the wax yet
