Running without a bystarter
Posted: Sun Feb 05, 2006 7:07 pm
by gman75
After limited sucess with a spree carb, I am going to try to use an elite carb on my elite engine.
Problem is my elite carb is cracked and deformed in the area where the bystarter fits to it, so a bystarter won't fit. How can I run the spree without a bystarter. Do I need to stick something in the hole before/after starting, etc?
Posted: Sun Feb 05, 2006 8:24 pm
by JF
It's probably not the best idea to run a carb that cannot utilize the bystarter correctly, but if you must, you might try finding an old bystarter needle valve assembly first. Then, push it into the hole in the middle where it normally goes, and tape it off good. Of course, then you won't have a working choke, so that defiantly shouldn't be your first option. I would highly suggest either getting another carb that isn't deformed, or try and repair the one you have. If you can, post a picture of the deformed area; that way either I or someone else can take a look at the pic, and let you know whether it is repairable(or worth repairing) or not.
JF
Posted: Sun Feb 05, 2006 8:31 pm
by noiseguy
...or get an aftermarket carb with a manual choke. Though I'm sure you're tired of spending on that beast.
Posted: Mon Feb 06, 2006 12:40 am
by maddog
Yes,
www.mopedwarehouse.com sells 14mm manual carbs in either lever or cable operated.
Posted: Mon Feb 06, 2006 11:47 am
by 85spreeelite
MadDog? 14mm is the stock size of elite carbs?
Posted: Mon Feb 06, 2006 1:28 pm
by gman75
JF,
If I tape off the bystarter hole like you said, it would be hard to start but fine once its warm and running, right?
Greg
Posted: Tue Feb 07, 2006 9:46 am
by sp00key
i ran mine whit out a bistarter and it was fine for like 4 mouth then i got a bistater and its ran like new but now i dont have a air box lol
Posted: Tue Feb 07, 2006 2:08 pm
by darat
HAHAH b/c u are to cheap to buy mine
Posted: Tue Feb 07, 2006 4:34 pm
by MySpree
yea MY BYSTARTER!!!
Posted: Tue Feb 07, 2006 4:53 pm
by darat
oh no he got a new one urs fryed...
Posted: Tue Feb 07, 2006 7:35 pm
by JF
Greg,
Yes, it'll be a little hard to start on cool mornings, but it should run fine once it's warmed up. Make sure that you have a needle valve assembly off of a by-starter pushed in there all the way until it seats, and then tape it off good, otherwise the bike might run too rich.
Good luck,
JF
