1986 Honda spree nq50. Piston rings.
Posted: Sat Feb 19, 2011 11:47 pm
by CamTastic
Whats the easiest way to put in some piston rings without breaking them?
I do not have a compressor for the rings. let me know the safest way to do so. thanks.
Re: 1986 Honda spree nq50. Piston rings.
Posted: Sun Feb 20, 2011 10:30 am
by evilone
The mark on the rings facing up. Then "roll" the rings down one groove at a time.
And you would want a ring expander not compressor :wink:
Posted: Sun Feb 20, 2011 3:11 pm
by CamTastic
I ment like whats the easiest way to put the head back on so you don't break the rings haha.
Posted: Sun Feb 20, 2011 3:21 pm
by Petrock's 1984 Spree
There is a how-to on how to install a bbk in the advanced tech section and it walks you through step by step :smile:
Posted: Sun Feb 20, 2011 3:39 pm
It is in the performance section of Wikispreedia.
http://hondaspree.net/wiki/index.php5?t ... it_Install
Posted: Sun Feb 20, 2011 4:02 pm
by CamTastic
Thanks guys. For a noobie would it be easier just to remove the motor from the frame and do it that way?
Posted: Sun Feb 20, 2011 4:49 pm
by evilone
CamTastic wrote:Thanks guys. For a noobie would it be easier just to remove the motor from the frame and do it that way?
I wouldn't remove motor.
Posted: Sun Feb 20, 2011 4:55 pm
by evilone
I just looked at that wiki link. I leave piston on the crank rod, compress rings by hand at the 10 and 2 locations, and slide cylinder down piston. Just hold the springs so the cutouts in the cylinder skirt are lined up with you fingers.
Posted: Tue Feb 22, 2011 10:50 pm
by eliteguy50
If you don't like the bending over, it can be. The spree frame is more intrusive than the sa50 frame that was used for those pictures. I usually just prop up the spree and drop the shock, allowing the motor to swing down more. This way you won't have to worry about oil/fuel lines or wires, but you have more room to work the cylinder on.
Posted: Tue Feb 22, 2011 10:52 pm
by eliteguy50
If this is the ring compressor you are talking about, I find doing it by hand to be easier on these engines.
http://www.amazon.com/OEM-27039-Piston- ... B0014WH9VQ
Posted: Tue Feb 22, 2011 10:59 pm
eliteguy50 wrote:If this is the ring compressor you are talking about, I find doing it by hand to be easier on these engines.
Don't bother with that, a simple hose clamp will work just fine.
