1984 spree carb setting
Posted: Thu Jun 02, 2011 12:02 am
I'm sure it's already somewhere on the forum, but what is the good screws settings on a 1984 honda spree carb?
Keeping Spree Elite Aero 50cc and Gyro Alive!
http://fastfoamfilter.com/hondaspree.net/phpBB3/
http://fastfoamfilter.com/hondaspree.net/phpBB3/viewtopic.php?t=19352
Ya..... I had to dig to find it too !lamie2012 wrote:I'm sure it's already somewhere on the forum, but what is the good screws settings on a 1984 honda spree carb?
Screw in air screw until it lightly seats then turn it
'84-'85 1 7/8th turns out
'86 1 1/2 turns out
'87 1 3/8ths turns out
Reset the idle speed with the throttle stop screw
Turn the air screw in or out to find the highest idle speed
Reset the idle speed with the throttle stop screw. Idle spec is 1800 rpm.
Make sure that the engine does not miss or run erratically. If necessary repeat steps 2 through 4
