SA50 VS SE50 oil pump differences?
Posted: Thu Nov 08, 2012 6:01 pm
by Mjh787s
I have a leaky S50 oil pump that needs replacing,
Can i put in the oil pump form an SA50? I have access to one cheap.
Re: SA50 VS SE50 oil pump differences?
Posted: Sat Nov 10, 2012 4:11 am
by Mjh787s
Looks like they are both AF05E engines so the answer isnYES
I am a little disappointed this got zero traction on the board
Posted: Wed Dec 12, 2012 11:08 pm
by Trinity1
I think I may have the same problem on my 2001 Elite...an SA50......how did the replacement go??
Posted: Thu Dec 13, 2012 1:16 pm
SA 50 and SE 50 are model codes, and do NOT designate what engine you have. The SE model only lasted 1 year in the US (1987) but its engine - the 05 - survived in the SA50 until 1993. After that the SA50 scooters were fitted with the AF16 engine. Pump swappability between the 05 and the 16 is uncertain.
Posted: Thu Dec 13, 2012 1:19 pm
by Mystic
88-93 sa50 and the 87 se50 have the afo5 engine whereas the 94-01 sa50 has the af16 engine. sa50p or se50p oil pumps dont produce the same output as the unrestricted version. as far as compatibility not exactly sure but i imagine if its a 94-01 you would just swap the shaft but dont quote me
Posted: Thu Dec 13, 2012 8:46 pm
by maddog
on the 94- 01 you can use a sym oil pump just swap the shaft, don't know about the older models.
